[Qgis-community-team] QGIS 2.14 doc available only in english?
DelazJ delazj at gmail.com
Sun Aug 7 23:34:21 PDT 2016
Hi Richard, all
French doc should be good now. I think I fixed all your reports (unless
meanwhile some new translations get wrong).
It was looooong.
Richard, HATS OFF TO YOU for all the times you manage this (for many
languages).
The processs is not straightforward at all and really time-consuming. Note
that user might also be able to build the doc (which is not always
straightforward and not always an easy step); I'm not sure that all
translators could take the lead on fixing those errors/warnings that make
their language fail. But I think that, as a community project, anyone could
be given the means to do it, we should empower translators. Hence an easier
and described process is needed.
 Just an idea (don't know how easy/complex it's): what about a web page
where we can report for all languages all errors/warnings? It would be
automatically generated when build is done so anyone would know what gets
wrong, can fix it and learn from it.
Regards,
Harrissou
2016-08-04 22:01 GMT+02:00 Richard Duivenvoorde <richard at duif.net>:
> On 04-08-16 18:44, DelazJ wrote:
> > Wow, looks like you found new ones.
> > Hope that all is done now!
> > Another rebuild, please?
> reading sources... [100%]
> docs/user_manual/working_with_vector/virtual_layers
> /home/richard/dev/qgis/git/QGIS-Documentation-2.14/
> source/docs/user_manual/plugins/plugins_evis.rst:361:
> WARNING: Inline strong start-string without end-string.
> source/docs/user_manual/processing_algs/taudem/specialized_grid_analysis_
> tools.rst:768:
> WARNING: Inline literal start-string without end-string.
> tools.rst:899:
> tools.rst:768:
> tools.rst:899:
> looking for now-outdated files... none found
> pickling environment... done
> checking consistency... done
> preparing documents... done
> writing output... [100%]
> source/docs/user_manual/introduction/qgis_configuration.rst:593:
> WARNING: undefined label: label_statusbar (if the link has no caption
> the label must precede a section header)
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20160808/5e4272f6/attachment.html>
More information about the Qgis-community-team mailing list
