[Qgis-community-team] Users Manual GRASS integration - what version to use?
Alexandre Neto
senhor.neto at gmail.com
Tue Feb 2 07:11:38 PST 2016
I have already created a pull request with Option B. I won't merge it for a
while, so others can give their opinion.
https://github.com/qgis/QGIS-Documentation/pull/801
Best Regards,
Alexandre Neto
Frank Sokolic <sokolic at worldonline.co.za> escreveu no dia terça, 2/02/2016
às 14:39:
> Hi Alexandre,
> I think the documentation should be based on GRASS 7 but I like your
> idea of indicating differences in brackets. Basing the documentation on
> GRASS 7 will hopefully persuade users to upgrade from 6.4.
> Regards, Frank.
> On 02/02/2016 15:21, Alexandre Neto wrote:
> > Hello all,
> > I have been updating the GRASS integration figures. To do that, I
> > generally follow the proposed exercises and commands. But GRASS 7.0
> > introduced some changes to modules and the commands (I guess from GRASS
> > 6.4) no longer work.
> > Since In QGIS you can now use GRASS 7.0 or GRASS 6.4, in what version
> > should be base our documentation. what version should we document?
> > A: Both
> > B: GRASS 6.4
> > C: GRASS 7
> > I would normally go to the C option, but since this actually only appear
> > 2 or 3 times, It won't hurt much to go for option A, something like this:
> > * Then click **r.relief** (or **r.shaded.relief** if using GRASS 6.4) to
> > open the module.
> > What do you think?
> > Alexandre
> > Alexandre Neto
> > @AlexNetoGeo
> > http://sigsemgrilhetas.wordpress.com
> > http://gisunchained.wordpress.com
> > Qgis-community-team mailing list for organizing community resources such
> as documentation, translation etc..
> > Qgis-community-team at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-community-team
Alexandre Neto
@AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20160202/7908ea85/attachment.html>
More information about the Qgis-community-team
