[Qgis-community-team] Users Manual GRASS integration - what version to use?
Radim Blazek
radim.blazek at gmail.com
Wed Feb 3 02:25:19 PST 2016
On Tue, Feb 2, 2016 at 2:21 PM, Alexandre Neto <senhor.neto at gmail.com> wrote:
> Hello all,
> I have been updating the GRASS integration figures. To do that, I generally
> follow the proposed exercises and commands. But GRASS 7.0 introduced some
> changes to modules and the commands (I guess from GRASS 6.4) no longer work.
> Since In QGIS you can now use GRASS 7.0 or GRASS 6.4, in what version should
> be base our documentation. what version should we document?
> A: Both
> B: GRASS 6.4
> C: GRASS 7
> I would normally go to the C option, but since this actually only appear 2
> or 3 times, It won't hurt much to go for option A, something like this:
> * Then click **r.relief** (or **r.shaded.relief** if using GRASS 6.4) to
> open the module.
This would be the best. Otherwise C and mention that 6.x
modules/options may slightly differ, pointing to
https://trac.osgeo.org/grass/wiki/Grass7/NewFeatures
Radim
> What do you think?
> Alexandre
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
> Qgis-community-team mailing list for organizing community resources such as
> documentation, translation etc..
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team
