[Qgis-community-team] installinf qgis on centos 6
Bachir Bachir
bachir_bac at yahoo.com
Wed Feb 10 04:50:21 PST 2016
Dear all,Any help please, i am installing grass71 on centos6 , i have the following message after running grass71sincere regards
[bachir at nexus ~]$ grass71
Starting GRASS GIS...g.gisenv: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /usr/local/grass7.1.svn-x86_64-pc-linux-gnu-08_02_2016/lib/libgrass_gis.7.1.svn.so)g.gisenv: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /usr/local/grass7.1.svn-x86_64-pc-linux-gnu-08_02_2016/lib/libgrass_datetime.7.1.svn.so)Traceback (most recent call last): File "/usr/local/grass7.1.svn-x86_64-pc-linux-gnu-08_02_2016/gui/wxpython/gis_set.py", line 31, in <module> from core import globalvar File "/usr/local/grass7.1.svn-x86_64-pc-linux-gnu-08_02_2016/gui/wxpython/core/globalvar.py", line 29, in <module> from core.debug import Debug File "/usr/local/grass7.1.svn-x86_64-pc-linux-gnu-08_02_2016/gui/wxpython/core/debug.py", line 72, in <module> Debug = DebugMsg() File "/usr/local/grass7.1.svn-x86_64-pc-linux-gnu-08_02_2016/gui/wxpython/core/debug.py", line 37, in __init__ self.SetLevel() File "/usr/local/grass7.1.svn-x86_64-pc-linux-gnu-08_02_2016/gui/wxpython/core/debug.py", line 43, in SetLevel self.debuglevel = int(grass.gisenv().get('WX_DEBUG', 0)) File "/usr/local/grass7.1.svn-x86_64-pc-linux-gnu-08_02_2016/etc/python/grass/script/core.py", line 952, in gisenv s = read_command("g.gisenv", flags='n') File "/usr/local/grass7.1.svn-x86_64-pc-linux-gnu-08_02_2016/etc/python/grass/script/core.py", line 458, in read_command process = pipe_command(*args, **kwargs) File "/usr/local/grass7.1.svn-x86_64-pc-linux-gnu-08_02_2016/etc/python/grass/script/core.py", line 433, in pipe_command return start_command(*args, **kwargs) File "/usr/local/grass7.1.svn-x86_64-pc-linux-gnu-08_02_2016/etc/python/grass/script/core.py", line 372, in start_command if debug_level() > 0: File "/usr/local/grass7.1.svn-x86_64-pc-linux-gnu-08_02_2016/etc/python/grass/script/core.py", line 1535, in debug_level _debug_level = int(gisenv().get('DEBUG', 0)) File "/usr/local/grass7.1.svn-x86_64-pc-linux-gnu-08_02_2016/etc/python/grass/script/core.py", line 952, in gisenv s = read_command("g.gisenv", flags='n') File "/usr/local/grass7.1.svn-x86_64-pc-linux-gnu-08_02_2016/etc/python/grass/script/core.py", line 461, in read_command return handle_errors(returncode, stdout, args, kwargs) File "/usr/local/grass7.1.svn-x86_64-pc-linux-gnu-08_02_2016/etc/python/grass/script/core.py", line 329, in handle_errors returncode=returncode)grass.exceptions.CalledModuleError: Module run None [b'g.gisenv', b'-n'] ended with errorProcess ended with non-zero return code 1. See errors in the (error) output.ERROR: Error in GUI startup. See messages above (if any) and if necessary, please report this error to the GRASS developers.On systems with package manager, make sure you have the right GUI package, probably named grass-gui, installed.To run GRASS GIS in text mode use the -text flag.Exiting...[bachir at nexus ~]$ uname -aLinux nexus 2.6.32-573.12.1.el6.x86_64 #1 SMP Tue Dec 15 21:19:08 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20160210/91562589/attachment.html>
More information about the Qgis-community-team
