[Qgis-community-team] Doc images and github
Richard Duivenvoorde
richard at duif.net
Mon Jan 25 12:34:51 PST 2016
On 25-01-16 11:06, Alexandre Neto wrote:
> Not an easy choice... I'm not very fond of duplicating substitutions
> images as I believe it will lead to pages with different icons because
> someone just update one place. Maybe it would be possible to have a
> common place with all images and some kind of script to copy the icons
> to a child forder near the rst?
FYI, I did a quick grep/count on all substitutions over ALL docs (so not
only manual).
While I agree with your point... there are not so many images used > 2
times...
|nix| 45
|win| 15
|osx| 9
|action| 2
|analysis| 1
|attributes| 4
|basic_statistics| 2
|browsebutton| 10
|buffer| 2
|calendarwidget| 0
|checkbox| 41
|checkbox_checked| 1
|checkbox_unchecked| 1
|check_geometry| 2
|centroids| 2
|clip| 2
|color| 0
|colormap| 0
|columnview| 0
|combobox| 0
|commandlinkbutton| 0
|convex_hull| 2
|coordinate_capture| 2
|copyright_label| 2
|CRS| 1
|create_gpx| 1
|dateedit| 0
|datetimeedit| 0
|dbmanager| 2
|define_projection| 2
|delaunay| 2
|delimited_text| 2
|dem_analysis| 1
|diagram| 2
|dial| 0
|dialogbuttonbox| 0
|difference| 2
|digitising| 0
|dissolve| 2
|dockwidget| 0
|doublespinbox| 0
|dxf2shp_converter| 3
|edit| 4
|eliminate| 1
|event_browser| 1
|event_id| 3
|evis_connect| 2
|evis_file| 2
|export_geometry| 2
|export_projection| 1
|extract_nodes| 2
|fontcombobox| 0
|frame| 0
|ftools| 2
|fullCumulativeStretch| 1
|FullHistogramStretch| 1
|gdal| 1
|gdal_about| 0
|gdal_assign_projection| 1
|gdal_contour| 1
|gdal_dem| 1
|gdal_edit| 0
|gdal_extract_projection| 1
|gdal_fillnodata| 1
|gdal_grid| 1
|gdal_merge| 1
|gdal_nearblack| 1
|gdal_polygonize| 1
|gdal_proximity| 1
|gdal_raster-clip| 1
|gdal_raster-overview| 1
|gdal_raster-paletted| 0
|gdal_raster-rgb| 1
|gdal_rasterize| 1
|gdal_reset| 0
|gdal_sieve| 1
|gdal_tileindex| 1
|gdal_tooltip| 0
|gdal_translate| 1
|gdal_vrt| 1
|gdal_warp| 1
|general| 2
|gentlelogo| 10
|geographic| 3
|geometry| 1
|geometrychecker| 2
|geometrysnapper| 2
|geoprocessing| 2
|georeferencer| 1
|geRasterometry| 0
|gps_importer| 2
|gpstrack_barchart| 2
|gpstrack_polarchart| 2
|graphicsview| 0
|grass| 2
|grass_close_mapset| 2
|grass_location| 1
|grass_new_mapset| 3
|grass_open_mapset| 2
|grass_region| 2
|grass_set_region| 1
|grass_region_edit| 1
|grass_tools| 3
|groupbox| 0
|groupboxcollapsible| 0
|heatmap| 4
|histogram| 0
|hscrollbar| 0
|hslider| 0
|hsplit| 0
|iconAboutConsole| 0
|iconClassBrowserConsole| 0
|iconClassConsole| 0
|iconClassTreeWidgetConsole| 0
|iconClearConsole| 0
|iconCloseTabEditorConsole| 0
|iconCodepadConsole| 0
|iconCommentEditorConsole| 0
|iconCopyEditorConsole| 0
|iconCutEditorConsole| 0
|iconFileTabsMenuConsole| 0
|iconFunctionTreeWidgetConsole| 0
|iconHelpConsole| 0
|iconHideToolConsole| 0
|iconIfaceConsole| 0
|iconMethodTreeWidgetConsole| 0
|iconNewTabEditorConsole| 0
|iconOpenConsole| 0
|iconPasteEditorConsole| 0
|iconQtCoreConsole| 0
|iconQtGuiConsole| 0
|iconRestoreTabsConsole| 0
|iconRunConsole| 0
|iconRunScriptConsole| 0
|iconSaveAsConsole| 0
|iconSaveConsole| 0
|iconScriptConsole| 0
|iconSettingsConsole| 0
|icon_newgpx| 1
|icon_dbmanager| 3
|icon_zonal_statistics| 1
|import_gpx| 1
|inputtext| 2
|interpolation| 2
|intersect| 2
|intersections| 2
|join| 2
|join_location| 2
|labels| 1
|layer_extent| 2
|locale| 1
|locked| 2
|mAction| 3
|mActionAdd| 1
|mActionAddAllToOverview| 2
|mActionAddArrow| 3
|mActionAddBasicShape| 3
|mActionAddDelimitedTextLayer| 0
|mActionAddGCPPoint| 1
|mActionAddHtml| 2
|mActionAddImage| 3
|mActionAddLayer| 1
|mActionAddLegend| 5
|mActionAddMap| 6
|mActionAddMssqlLayer| 2
|mActionAddNonDbLayer| 1
|mActionAddOgrLayer| 4
|mActionAddOracleLayer| 1
|mActionAddPart| 4
|mActionAddPostgisLayer| 2
|mActionAddRasterLayer| 7
|mActionAddRing| 4
|mActionAddSpatiaLiteLayer| 3
|mActionAddWmsLayer| 3
|mActionAlignBottom| 2
|mActionAlignHCenter| 2
|mActionAlignLeft| 4
|mActionAlignRight| 2
|mActionAlignTop| 2
|mActionAlignVCenter| 2
|mActionAllEdits| 2
|mActionAnnotation| 2
|mActionArrowDown| 1
|mActionArrowLeft| 0
|mActionArrowRight| 1
|mActionArrowUp| 0
|mActionAtlasFirst| 2
|mActionAtlasLast| 2
|mActionAtlasNext| 2
|mActionAtlasPrev| 2
|mActionAtlasSettings| 1
|mActionCancelEdits| 1
|mActionCalculateField| 6
|mActionCaptureBoundary| 1
|mActionCaptureCentroid| 1
|mActionCaptureLine| 4
|mActionCapturePoint| 4
|mActionCapturePolygon| 5
|mActionChangeLabelProperties| 2
|mActionCheckQgisVersion| 2
|mActionCollapseTree| 2
|mActionComposerManager| 4
|mActionContextHelp| 1
|mActionCopySelected| 3
|mActionCustomProjection| 3
|mActionDeleteAttribute| 3
|mActionDeleteGCPPoint| 1
|mActionDeletePart| 4
|mActionDeleteRing| 4
|mActionDeleteSelected| 4
|mActionDeselectAll| 2
|mActionDraw| 5
|mActionDupComposer| 2
|mActionDuplicateLayer| 1
|mActionEditCopy| 5
|mActionEditCut| 4
|mActionEditPaste| 4
|mActionExpandNewTree| 2
|mActionExpandTree| 2
|mActionExportMapServer| 1
|mActionFileExit| 2
|mActionFileNew| 3
|mActionFileOpen| 6
|mActionFilePrint| 5
|mActionFileSave| 6
|mActionFileSaveAs| 9
|mActionFillRing| 2
|mActionFilter| 1
|mActionFolder| 2
|mActionFormAnnotation| 2
|mActionFullHistogramStretch| 1
|mActionGDALScript| 2
|mActionGroupItems| 2
|mActionHelpAbout| 2
|mActionHelpContents| 2
|mActionHelpSponsors| 2
|mActionHideAllLayers| 2
|mActionmIconExpressionEditorOpen| 1
|mActionIdentify| 6
|mActionInOverview| 2
|mActionInvertSelection| 2
|mActionLabel| 4
|mActionLabeling| 4
|mActionLink| 1
|mActionLinkGeorefToQGis| 2
|mActionLinkQGisToGeoref| 2
|mActionLoadGCPpoints| 1
|mActionLocalHistogramStretch| 1
|mActionLowerItems| 2
|mActionMapTips| 3
|mActionMeasure| 3
|mActionMeasureAngle| 2
|mActionMeasureArea| 2
|mActionMergeFeatAttributes| 3
|mActionMergeFeatures| 3
|mActionMoveFeature| 4
|mActionMoveGCPPoint| 1
|mActionMoveItemContent| 4
|mActionMoveItemsToBottom| 2
|mActionMoveItemsToTop| 2
|mActionMoveLabel| 2
|mActionNewAttribute| 3
|mActionNewBookmark| 2
|mActionNewComposer| 6
|mActionNewSpatiaLiteLayer| 2
|mActionNewVectorLayer| 3
|mActionNodeTool| 4
|mActionOffsetCurve| 4
|mActionOpenRaster| 0
|mActionOpenTable| 7
|mActionOptions| 9
|mActionPan| 6
|mActionPinLabels| 1
|mActionProjectProperties| 3
|mActionPropertyItem| 2
|mActionQgisHomePage| 2
|mActionRaiseItems| 3
|mActionRedo| 5
|mActionRemove| 1
|mActionRemoveAllFromOverview| 1
|mActionRemoveLayer| 3
|mActionReshape| 4
|mActionRollbackEdits| 1
|mActionRotateFeature| 1
|mActionRotateLabel| 1
|mActionRotatePointSymbols| 3
|mActionSaveAsPDF| 4
|mActionSaveAsSVG| 5
|mActionSaveEdits| 3
|mActionSaveGCPpointsAs| 1
|mActionSaveMapAsImage| 6
|mActionScaleBar| 4
|mActionSelect| 10
|mActionSelectFreehand| 2
|mActionSelectPan| 1
|mActionSelectPolygon| 2
|mActionSelectRadius| 2
|mActionSelectRectangle| 2
|mActionSelectedToTop| 2
|mActionShowAllLayers| 3
|mActionShowBookmarks| 2
|mActionShowHideLabels| 1
|mActionShowPinnedLabels| 1
|mActionShowPluginManager| 6
|mActionShowPresets| 3
|mActionSignMinus| 3
|mActionSignPlus| 6
|mActionSimplify| 4
|mActionSplitFeatures| 5
|mActionSplitParts| 3
|mActionStartGeoref| 2
|mActionTextAnnotation| 2
|mActionToggleEditing| 6
|mActionTouch| 1
|mActionTransformSettings| 2
|mActionUndo| 5
|mActionUnGroupItems| 1
|mActionUnlink| 1
|mActionUnselectAttributes| 1
|mActionWhatsThis| 2
|mActionZoomActual| 3
|mActionZoomFullExtent| 5
|mActionZoomIn| 8
|mActionZoomLast| 3
|mActionZoomNext| 3
|mActionZoomOut| 8
|mActionZoomToLayer| 4
|mActionZoomToSelected| 4
|management| 1
|mapserver_export| 1
|matrix| 2
|mean| 2
|merge_shapes| 2
|metadata| 2
|metasearch| 2
|mGeorefRun| 1
|mIconAtlas| 3
|mIconColorBox| 2
|mIconColorPicker| 2
|mIconColorSwatches| 2
|mIconColorWheel| 2
|mIconDataDefine| 6
|mIconExpression| 1
|mIconExpressionSelect| 4
|mIconImport| 1
|mIconLock| 2
|mIconNew| 2
|mIconProjectionDisabled| 2
|mIconProjectionEnabled| 3
|mIconRasterGroup| 1
|mIconRasterLink| 1
|mIconStopRendering| 1
|mIconZip| 1
|multi_to_single| 2
|neighbor| 2
|north_arrow| 2
|offline_editing_copy| 3
|offline_editing_sync| 2
|oracle_raster| 3
|osm_addRelation| 1
|osm_createLine| 1
|osm_createPoint| 1
|osm_createPolygon| 1
|osm_createRelation| 1
|osm_download| 1
|osm_editRelation| 1
|osm_featureManager| 1
|osm_generateTags| 1
|osm_identify| 1
|osm_import| 1
|osm_load| 1
|osm_move| 1
|osm_questionMark| 1
|osm_removeFeat| 1
|osm_removeTag| 0
|osm_save| 1
|osm_upload| 0
|PanToSelected| 3
|pencil| 2
|plugin| 3
|plugin_installed| 1
|plugin_installer| 2
|plugin_upgrade| 1
|proc_commander| 1
|proc_history| 1
|proc_model| 1
|proc_option| 1
|proc_result| 1
|proc_toolbox| 1
|qgissplash| 0
|radiobuttonon| 15
|radiobuttonoff| 10
|random_points| 2
|random_selection| 2
|raster-info| 3
|raster-interpolate| 2
|raster-stats| 2
|raster_terrain| 2
|regular_points| 2
|RemoveAllOVerview| 2
|roadgraph| 1
|sampling| 1
|scale_bar| 2
|selectcolor| 3
|selectcreatelayer| 2
|selectnumber| 9
|selectstring| 17
|selectesubsetlayer| 2
|select_location| 2
|ShowRasterCalculator| 1
|single_to_multi| 2
|slider| 6
|spatialquery| 3
|spiticon| 2
|split_layer| 2
|sub_selection| 2
|sum_lines| 2
|sum_points| 2
|sym_difference| 2
|symbology| 1
|simplify| 2
|tab| 1
|to_lines| 2
|topologychecker| 2
|tracking| 2
|transformed| 1
|union| 2
|unique| 2
|unlocked| 2
|user| 1
|vector_grid| 2
|wcs| 1
|wfs| 4
More information about the Qgis-community-team
