[Qgis-community-team] Doc images and github
    Otto Dassau
    otto at qgis.org
    Tue Jan 26 05:08:42 PST 2016
Hi Richard,
thanks a lot for this grep/count. In this case I would vote for option 2:
..."define figures locally in the rst file where you use them. This has as
drawback that very often used inline images (like the checkbox) are defined
+ image copied very often. BUT the nice thing about it is that IF you define
them in the rst file, Github is able to resolve those SO they show up as
inline images there."
Regards
Otto
Am Mon, 25 Jan 2016 21:34:51 +0100
schrieb Richard Duivenvoorde <richard at duif.net>:
> On 25-01-16 11:06, Alexandre Neto wrote:
> > Not an easy choice... I'm not very fond of duplicating substitutions
> > images as I believe it will lead to pages with different icons because
> > someone just update one place. Maybe it would be possible to have a
> > common place with all  images and some kind of script to copy the icons
> > to a child forder near the rst?
> FYI, I did a quick grep/count on all substitutions over ALL docs (so not
> only manual).
> While I agree with your point... there are not so many images used > 2
> times...
> |nix| 45
> |win| 15
> |osx| 9
> |action| 2
> |analysis| 1
> |attributes| 4
> |basic_statistics| 2
> |browsebutton| 10
> |buffer| 2
> |calendarwidget| 0
> |checkbox| 41
> |checkbox_checked| 1
> |checkbox_unchecked| 1
> |check_geometry| 2
> |centroids| 2
> |clip| 2
> |color| 0
> |colormap| 0
> |columnview| 0
> |combobox| 0
> |commandlinkbutton| 0
> |convex_hull| 2
> |coordinate_capture| 2
> |copyright_label| 2
> |CRS| 1
> |create_gpx| 1
> |dateedit| 0
> |datetimeedit| 0
> |dbmanager| 2
> |define_projection| 2
> |delaunay| 2
> |delimited_text| 2
> |dem_analysis| 1
> |diagram| 2
> |dial| 0
> |dialogbuttonbox| 0
> |difference| 2
> |digitising| 0
> |dissolve| 2
> |dockwidget| 0
> |doublespinbox| 0
> |dxf2shp_converter| 3
> |edit| 4
> |eliminate| 1
> |event_browser| 1
> |event_id| 3
> |evis_connect| 2
> |evis_file| 2
> |export_geometry| 2
> |export_projection| 1
> |extract_nodes| 2
> |fontcombobox| 0
> |frame| 0
> |ftools| 2
> |fullCumulativeStretch| 1
> |FullHistogramStretch| 1
> |gdal| 1
> |gdal_about| 0
> |gdal_assign_projection| 1
> |gdal_contour| 1
> |gdal_dem| 1
> |gdal_edit| 0
> |gdal_extract_projection| 1
> |gdal_fillnodata| 1
> |gdal_grid| 1
> |gdal_merge| 1
> |gdal_nearblack| 1
> |gdal_polygonize| 1
> |gdal_proximity| 1
> |gdal_raster-clip| 1
> |gdal_raster-overview| 1
> |gdal_raster-paletted| 0
> |gdal_raster-rgb| 1
> |gdal_rasterize| 1
> |gdal_reset| 0
> |gdal_sieve| 1
> |gdal_tileindex| 1
> |gdal_tooltip| 0
> |gdal_translate| 1
> |gdal_vrt| 1
> |gdal_warp| 1
> |general| 2
> |gentlelogo| 10
> |geographic| 3
> |geometry| 1
> |geometrychecker| 2
> |geometrysnapper| 2
> |geoprocessing| 2
> |georeferencer| 1
> |geRasterometry| 0
> |gps_importer| 2
> |gpstrack_barchart| 2
> |gpstrack_polarchart| 2
> |graphicsview| 0
> |grass| 2
> |grass_close_mapset| 2
> |grass_location| 1
> |grass_new_mapset| 3
> |grass_open_mapset| 2
> |grass_region| 2
> |grass_set_region| 1
> |grass_region_edit| 1
> |grass_tools| 3
> |groupbox| 0
> |groupboxcollapsible| 0
> |heatmap| 4
> |histogram| 0
> |hscrollbar| 0
> |hslider| 0
> |hsplit| 0
> |iconAboutConsole| 0
> |iconClassBrowserConsole| 0
> |iconClassConsole| 0
> |iconClassTreeWidgetConsole| 0
> |iconClearConsole| 0
> |iconCloseTabEditorConsole| 0
> |iconCodepadConsole| 0
> |iconCommentEditorConsole| 0
> |iconCopyEditorConsole| 0
> |iconCutEditorConsole| 0
> |iconFileTabsMenuConsole| 0
> |iconFunctionTreeWidgetConsole| 0
> |iconHelpConsole| 0
> |iconHideToolConsole| 0
> |iconIfaceConsole| 0
> |iconMethodTreeWidgetConsole| 0
> |iconNewTabEditorConsole| 0
> |iconOpenConsole| 0
> |iconPasteEditorConsole| 0
> |iconQtCoreConsole| 0
> |iconQtGuiConsole| 0
> |iconRestoreTabsConsole| 0
> |iconRunConsole| 0
> |iconRunScriptConsole| 0
> |iconSaveAsConsole| 0
> |iconSaveConsole| 0
> |iconScriptConsole| 0
> |iconSettingsConsole| 0
> |icon_newgpx| 1
> |icon_dbmanager| 3
> |icon_zonal_statistics| 1
> |import_gpx| 1
> |inputtext| 2
> |interpolation| 2
> |intersect| 2
> |intersections| 2
> |join| 2
> |join_location| 2
> |labels| 1
> |layer_extent| 2
> |locale| 1
> |locked| 2
> |mAction| 3
> |mActionAdd| 1
> |mActionAddAllToOverview| 2
> |mActionAddArrow| 3
> |mActionAddBasicShape| 3
> |mActionAddDelimitedTextLayer| 0
> |mActionAddGCPPoint| 1
> |mActionAddHtml| 2
> |mActionAddImage| 3
> |mActionAddLayer| 1
> |mActionAddLegend| 5
> |mActionAddMap| 6
> |mActionAddMssqlLayer| 2
> |mActionAddNonDbLayer| 1
> |mActionAddOgrLayer| 4
> |mActionAddOracleLayer| 1
> |mActionAddPart| 4
> |mActionAddPostgisLayer| 2
> |mActionAddRasterLayer| 7
> |mActionAddRing| 4
> |mActionAddSpatiaLiteLayer| 3
> |mActionAddWmsLayer| 3
> |mActionAlignBottom| 2
> |mActionAlignHCenter| 2
> |mActionAlignLeft| 4
> |mActionAlignRight| 2
> |mActionAlignTop| 2
> |mActionAlignVCenter| 2
> |mActionAllEdits| 2
> |mActionAnnotation| 2
> |mActionArrowDown| 1
> |mActionArrowLeft| 0
> |mActionArrowRight| 1
> |mActionArrowUp| 0
> |mActionAtlasFirst| 2
> |mActionAtlasLast| 2
> |mActionAtlasNext| 2
> |mActionAtlasPrev| 2
> |mActionAtlasSettings| 1
> |mActionCancelEdits| 1
> |mActionCalculateField| 6
> |mActionCaptureBoundary| 1
> |mActionCaptureCentroid| 1
> |mActionCaptureLine| 4
> |mActionCapturePoint| 4
> |mActionCapturePolygon| 5
> |mActionChangeLabelProperties| 2
> |mActionCheckQgisVersion| 2
> |mActionCollapseTree| 2
> |mActionComposerManager| 4
> |mActionContextHelp| 1
> |mActionCopySelected| 3
> |mActionCustomProjection| 3
> |mActionDeleteAttribute| 3
> |mActionDeleteGCPPoint| 1
> |mActionDeletePart| 4
> |mActionDeleteRing| 4
> |mActionDeleteSelected| 4
> |mActionDeselectAll| 2
> |mActionDraw| 5
> |mActionDupComposer| 2
> |mActionDuplicateLayer| 1
> |mActionEditCopy| 5
> |mActionEditCut| 4
> |mActionEditPaste| 4
> |mActionExpandNewTree| 2
> |mActionExpandTree| 2
> |mActionExportMapServer| 1
> |mActionFileExit| 2
> |mActionFileNew| 3
> |mActionFileOpen| 6
> |mActionFilePrint| 5
> |mActionFileSave| 6
> |mActionFileSaveAs| 9
> |mActionFillRing| 2
> |mActionFilter| 1
> |mActionFolder| 2
> |mActionFormAnnotation| 2
> |mActionFullHistogramStretch| 1
> |mActionGDALScript| 2
> |mActionGroupItems| 2
> |mActionHelpAbout| 2
> |mActionHelpContents| 2
> |mActionHelpSponsors| 2
> |mActionHideAllLayers| 2
> |mActionmIconExpressionEditorOpen| 1
> |mActionIdentify| 6
> |mActionInOverview| 2
> |mActionInvertSelection| 2
> |mActionLabel| 4
> |mActionLabeling| 4
> |mActionLink| 1
> |mActionLinkGeorefToQGis| 2
> |mActionLinkQGisToGeoref| 2
> |mActionLoadGCPpoints| 1
> |mActionLocalHistogramStretch| 1
> |mActionLowerItems| 2
> |mActionMapTips| 3
> |mActionMeasure| 3
> |mActionMeasureAngle| 2
> |mActionMeasureArea| 2
> |mActionMergeFeatAttributes| 3
> |mActionMergeFeatures| 3
> |mActionMoveFeature| 4
> |mActionMoveGCPPoint| 1
> |mActionMoveItemContent| 4
> |mActionMoveItemsToBottom| 2
> |mActionMoveItemsToTop| 2
> |mActionMoveLabel| 2
> |mActionNewAttribute| 3
> |mActionNewBookmark| 2
> |mActionNewComposer| 6
> |mActionNewSpatiaLiteLayer| 2
> |mActionNewVectorLayer| 3
> |mActionNodeTool| 4
> |mActionOffsetCurve| 4
> |mActionOpenRaster| 0
> |mActionOpenTable| 7
> |mActionOptions| 9
> |mActionPan| 6
> |mActionPinLabels| 1
> |mActionProjectProperties| 3
> |mActionPropertyItem| 2
> |mActionQgisHomePage| 2
> |mActionRaiseItems| 3
> |mActionRedo| 5
> |mActionRemove| 1
> |mActionRemoveAllFromOverview| 1
> |mActionRemoveLayer| 3
> |mActionReshape| 4
> |mActionRollbackEdits| 1
> |mActionRotateFeature| 1
> |mActionRotateLabel| 1
> |mActionRotatePointSymbols| 3
> |mActionSaveAsPDF| 4
> |mActionSaveAsSVG| 5
> |mActionSaveEdits| 3
> |mActionSaveGCPpointsAs| 1
> |mActionSaveMapAsImage| 6
> |mActionScaleBar| 4
> |mActionSelect| 10
> |mActionSelectFreehand| 2
> |mActionSelectPan| 1
> |mActionSelectPolygon| 2
> |mActionSelectRadius| 2
> |mActionSelectRectangle| 2
> |mActionSelectedToTop| 2
> |mActionShowAllLayers| 3
> |mActionShowBookmarks| 2
> |mActionShowHideLabels| 1
> |mActionShowPinnedLabels| 1
> |mActionShowPluginManager| 6
> |mActionShowPresets| 3
> |mActionSignMinus| 3
> |mActionSignPlus| 6
> |mActionSimplify| 4
> |mActionSplitFeatures| 5
> |mActionSplitParts| 3
> |mActionStartGeoref| 2
> |mActionTextAnnotation| 2
> |mActionToggleEditing| 6
> |mActionTouch| 1
> |mActionTransformSettings| 2
> |mActionUndo| 5
> |mActionUnGroupItems| 1
> |mActionUnlink| 1
> |mActionUnselectAttributes| 1
> |mActionWhatsThis| 2
> |mActionZoomActual| 3
> |mActionZoomFullExtent| 5
> |mActionZoomIn| 8
> |mActionZoomLast| 3
> |mActionZoomNext| 3
> |mActionZoomOut| 8
> |mActionZoomToLayer| 4
> |mActionZoomToSelected| 4
> |management| 1
> |mapserver_export| 1
> |matrix| 2
> |mean| 2
> |merge_shapes| 2
> |metadata| 2
> |metasearch| 2
> |mGeorefRun| 1
> |mIconAtlas| 3
> |mIconColorBox| 2
> |mIconColorPicker| 2
> |mIconColorSwatches| 2
> |mIconColorWheel| 2
> |mIconDataDefine| 6
> |mIconExpression| 1
> |mIconExpressionSelect| 4
> |mIconImport| 1
> |mIconLock| 2
> |mIconNew| 2
> |mIconProjectionDisabled| 2
> |mIconProjectionEnabled| 3
> |mIconRasterGroup| 1
> |mIconRasterLink| 1
> |mIconStopRendering| 1
> |mIconZip| 1
> |multi_to_single| 2
> |neighbor| 2
> |north_arrow| 2
> |offline_editing_copy| 3
> |offline_editing_sync| 2
> |oracle_raster| 3
> |osm_addRelation| 1
> |osm_createLine| 1
> |osm_createPoint| 1
> |osm_createPolygon| 1
> |osm_createRelation| 1
> |osm_download| 1
> |osm_editRelation| 1
> |osm_featureManager| 1
> |osm_generateTags| 1
> |osm_identify| 1
> |osm_import| 1
> |osm_load| 1
> |osm_move| 1
> |osm_questionMark| 1
> |osm_removeFeat| 1
> |osm_removeTag| 0
> |osm_save| 1
> |osm_upload| 0
> |PanToSelected| 3
> |pencil| 2
> |plugin| 3
> |plugin_installed| 1
> |plugin_installer| 2
> |plugin_upgrade| 1
> |proc_commander| 1
> |proc_history| 1
> |proc_model| 1
> |proc_option| 1
> |proc_result| 1
> |proc_toolbox| 1
> |qgissplash| 0
> |radiobuttonon| 15
> |radiobuttonoff| 10
> |random_points| 2
> |random_selection| 2
> |raster-info| 3
> |raster-interpolate| 2
> |raster-stats| 2
> |raster_terrain| 2
> |regular_points| 2
> |RemoveAllOVerview| 2
> |roadgraph| 1
> |sampling| 1
> |scale_bar| 2
> |selectcolor| 3
> |selectcreatelayer| 2
> |selectnumber| 9
> |selectstring| 17
> |selectesubsetlayer| 2
> |select_location| 2
> |ShowRasterCalculator| 1
> |single_to_multi| 2
> |slider| 6
> |spatialquery| 3
> |spiticon| 2
> |split_layer| 2
> |sub_selection| 2
> |sum_lines| 2
> |sum_points| 2
> |sym_difference| 2
> |symbology| 1
> |simplify| 2
> |tab| 1
> |to_lines| 2
> |topologychecker| 2
> |tracking| 2
> |transformed| 1
> |union| 2
> |unique| 2
> |unlocked| 2
> |user| 1
> |vector_grid| 2
> |wcs| 1
> |wfs| 4
> Qgis-community-team mailing list for organizing community resources such
> as documentation, translation etc.. Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
Otto Dassau
QGIS Project Steering Committee Member
otto at qgis.org
More information about the Qgis-community-team
