[Qgis-community-team] Manual update can officially start
Alexandre Neto
senhor.neto at gmail.com
Tue Jan 26 13:42:26 PST 2016
Hello,
Can I please ask that anyone that detects outdated figures, please label
the issue with screenshot, and, if your job is done, assign the issue to me
(aka SrNetoChan).
Same procedure if you want me to create a new figure, but describe on
comments what you have in mind or create a screenshot in any other
operative system and I will recreate on ubuntu environment.
Alexandre Neto
A 19h33 Ter, 26 de Jan de 2016, Otto Dassau <otto at qgis.org> escreveu:
> Hi Documentation team,
> we can now start with the manual update in github. All documenters who sent
> me a login have write access to the QGIS Documentation repo in github,
> because that will speeds up the work. You can work on the manual, check
> if it builds and then apply the change to the repository.
> Here is the procedure to update the QGIS manual:
> Login to github and edit manual
> 1) login with your github account and go to the QGIS Documentation issue
> list at
> https://github.com/qgis/QGIS-Documentation/issues?q=is%3Aopen+is%3Aissue+label%3A%22User+Manual%22
> 2) select an issue you want to work on by clicking on the issue assign
> yourself.
> 3) change to
> https://github.com/qgis/QGIS-Documentation/tree/master/source/docs/user_manual
> and search for the RST file to update/add the issue.
> 4) Then save the changes by clicking on 'create a new branch for this
> commit
> and start a pull request'
> 5) Click on 'Propose file changes' , leave a comment about your change and
> click on 'Create Pull request'
> Check the build
> The Rull Request automatically starts a Travis build, where you can check,
> if your changes build properly, looking at QGIS-Website build by Travis at
> https://travis-ci.org/qgis/QGIS-Documentation/builds
> It takes about 10 minutes before the build has finished.
> After build has finished without errors go to
> https://github.com/qgis/QGIS-Documentation/pulls, select your Pull Request
> and click on 'Merge pull request'.
> If there are errors, go back to step 3, fix your changes and so on.... and
> if something doesn't work as expected or if you have questions, please
> write
> to the list and we will try to help.
> Regards,
> Otto
> Qgis-community-team mailing list for organizing community resources such
> as documentation, translation etc..
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetaswordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20160126/4b088dd0/attachment.html>
More information about the Qgis-community-team
