[Qgis-community-team] New QGIS Documentation Subscriber
DelazJ
delazj at gmail.com
Sat Jun 4 03:58:45 PDT 2016
Hi,.
2016-06-04 7:25 GMT+02:00 Angie Garcia <amg832 at outlook.com>:
> To move forward with editing documentation, I have created a sample of how
> the User Guide 2.14 could be modified. Keep in mind this is only one idea,
> all input is welcomed.
Looking forward to reading this doc. No worry we are open to changes as far
as they improve the project are sustainable and worth the effort
All changes were indicated with red font, I made changes up to end of
> chapter 1. Need to upload pdf to repository. Can someone provide best way
> to do this? I have created my GitHub account and fork (created copy of
> repository), installed the Git, but not created the local repository.
> Actually, from my experience, having a local repository is not that
mandatory (except to keep uptodate your _master_ branch). I only needed it
because:
- I wanted a clean history: I couldn't do all my changes in one go so
needed to use git commands to merge them in one change (*commit*)
- I had to manage conflicts between my proposal (*pull request*) and
changes done to the repo by others meanwhile
- and to have branch(es) that follow official master branch, (purists could
say this is mandatory - but you can workaround thanks to GitHub web
interface)
I worked on document aesthetics, content, consistency and followed along
> using QGIS software. However, if a re-design change is made to the
> document, it would be a good idea to update other manuals.
> consistency, improvement, sustainability, new ideas are all welcome...
> The idea will be to edit one section/chapter at a time then upload it to
> the repository.
I think a more sustainable process would be using github directly to
perform your changes so let's do a step by step modification, now that you
have a github account. Let's say you'll like to fix things in the "Getting
Started" chapter (
http://docs.qgis.org/testing/en/docs/user_manual/introduction/getting_started.html
1. Click the "Fix Me" link at the bottom of the page
2. this would open
https://github.com/qgis/QGIS-Documentation/edit/master/source/docs/user_manual/introduction/getting_started.rst.
A message at the top of the page will tell you that you don't have write
access to this repo and your changes will be applied in a branch of your
forked repo.
2b. If your master branch is even with qgis/master, you can replace the
link above by yours
https://github.com/amg832/QGIS-Documentation/edit/master/source/docs/user_manual/introduction/getting_started.rst
3. following guidelines available at
http://docs.qgis.org/testing/en/docs/documentation_guidelines/, do your
changes
4. When you finish, at the bottom of the page, comment a bit what your
changes are about and click on "Propose File change". This will generate a
new branch (*patch-xxx* - i can't recall if you can name the branch) in
your repo
4b. If you use your own master branch (as said in 2b), you're strongly
advised to commit in a new branch with a remindable name (let's use
getStart). Avoid committing your changes in the master branch. Actually,
it's good to have a branch even with the main project and master is usually
used for that. Keep it just to merge qgis/master changes inside, not yours.
Now you have a file in
https://github.com/amg832/QGIS-Documentation/patch-1/source/docs/user_manual/introduction/getting_started.rst
(or
https://github.com/amg832/QGIS-Documentation/getStart/source/docs/user_manual/introduction/getting_started.rst
if 2b) different from the official doc with your changes. Now you need to
inform about your changes and ask for merging (pull request to the main
repo).
5. You get a "Comparing changes" page. Ensure that the base fork is
*qgis/QGIS-Documentation* and its branch *master *
6. Click on "Create pull request", fill some info if needed and apply
7. A new PR is added to https://github.com/qgis/QGIS-Documentation/pulls
and every body can look or comment it (under files tab).
8. And a repo maintainer can merge your work directly with the official doc
if all is ok in one-click.
9. Until your PR is merged with the repo, you can add modifications to your
proposal. Actually any new changes done to your branch patch-xxx (or
getStart) is appended to your PR. Do it if the change has to do with your
initial pull request, otherwise create a new branch with those changes
following steps above.
Sorry for my long message if you already knew all this. There are other
ways to do it but this one looked straight for me when I began
contributing. Hope that it's useful to someone.
Regards,
Harrissou
2016-06-04 10:03 GMT+02:00 Alexandre Neto <senhor.neto at gmail.com>:
> If you wanna share a PDF you could put it in Dropbox or something similar.
> The repository is not the place for it.
> A sáb, 4/06/2016, 06:30, Angie Garcia <amg832 at outlook.com> escreveu:
>> how the User Guide 2.14 could be modified. Keep in mind this is only one
>> idea, all input is welcomed.
>> the repository.
>> Best Regards,
>> Angie
>> ________________________________________
>> From: Qgis-community-team <qgis-community-team-bounces at lists.osgeo.org>
>> on behalf of Yves Jacolin <yjacolin at free.fr>
>> Sent: Thursday, June 2, 2016 5:17:40 AM
>> To: qgis-community-team at lists.osgeo.org
>> Subject: Re: [Qgis-community-team] New QGIS Documentation Subscriber
>> Hello,
>> A good start for an english native speaker could be:
>> * make review of Pull request
>> * proof read the doc to see english error, etc. and create issue with the
>> correct sentence.
>> That would be a really huge enhancement, but also a hard work.
>> Y.
>> On Thursday, June 02, 2016 1:20:25 DelazJ wrote:
>> > Hi,
>> > Welcome Angie and thanks for offering your help!
>> > As already pointed out by Richard you'll find few recommendations to
>> follow
>> > when contributing to QGIS Documentation writing at
>> > But prior to this, In order to contribute, you'll need as stated at
>> > http://qgis.org/en/site/getinvolved/document.html#becoming-a-documenter
>> to:
>> > - create a GitHub account
>> > - and fork (copy) the doc repo
>> > Once done, feel free to pick any issue in the list and write about. You
>> can
>> > also go through the doc being written (docs.qgis.org/testing/en/docs)
>> and
>> > fix potential typo errors, "bad english" (most of us are not native
>> > speaker) or review/comment contributions of others (
>> > https://github.com/qgis/QGIS-Documentation/pulls).
>> > Once again, welcome to you and if something is unclear, just ask.
>> Someone
>> > will try to explain to you.
>> > Regards,
>> > Harrissou
>> > 2016-06-02 0:17 GMT+02:00 Alexandre Neto <senhor.neto at gmail.com>:
>> > > Angie,
>> > > Welcome to the team. Thanks you for helping us with the docs.
>> > > I normally do the screenshots, so anything you need, let me know. Are
>> you
>> > > on github already?
>> > > Alexandre Beto
>> > > A qua, 1/06/2016, 22:50, Angie Garcia <amg832 at outlook.com> escreveu:
>> > >> Richard,
>> > >> English is my primary language. Read QGIS is natively developed in
>> > >> English, if you need assistance in looking at text before pulling it
>> into
>> > >> the docs, glad to help just need to know what needs to be done.
>> > >> Best Regards,
>> > >> Angie
>> > >> From: Richard Duivenvoorde <rdmailings at duif.net>
>> > >> Sent: Tuesday, May 31, 2016 11:53:43 PM
>> > >> To: Angie Garcia
>> > >> Cc: dassau at gbd-consult.de; Junior Delaz; Yves Jacolin;
>> qgis-community
>> > >> Subject: Re: New QGIS Documentation Subscriber
>> > >> On 31-05-16 22:33, Angie Garcia wrote:
>> > >> > Hi Richard,
>> > >> > I have recently subscribed and would like to participate with
>> updating
>> > >> > User Guide and assist in suggestions to aid in the documentation
>> work
>> > >> > flow. In going through all online/materials, it mentioned that one
>> > >> > should contact team lead in specific area of interest to get some
>> > >> > assistance in the process. I have cc Otto as he was the person I
>> sent
>> > >> > email to, however, have not heard from him and thought you might be
>> > >> > able
>> > >> > to help me or point me in the right direction to move forward.
>> > >> > Is there a new welcoming documentation packet which helps one get
>> > >> > setup,
>> > >> > have a mailing list of individuals to contact, talks a little
>> about the
>> > >> > various emails and limitations, etc...
>> > >> Hi Angie,
>> > >> For what I know this:
>> > >> are the guidelines. In the README at:
>> > >> is more information about how to actually BUILD the docs.
>> > >> Note that it is actually not persee nessecary to build it yourself.
>> If
>> > >> you follow the 'fix me' link in the footer of the pages on current
>> > >> 'testing' (==2.14 to be) version:
>> > >> http://docs.qgis.org/testing/en/docs/user_manual/index.html
>> > >> you can write/fix smaller parts of the docs in Github.
>> > >> I added Harrisou and Yves in cc, they have been mostly active I think
>> > >> recently, and maybe can give you a hand too.
>> > >> I will also sent this email to the community list where most document
>> > >> writers hang out.
>> > >> Here:
>> > >> https://github.com/qgis/QGIS-Documentation/issues
>> > >> all issues labeld QGIS 2.14
>> > >> https://github.com/qgis/QGIS-Documentation/milestones/QGIS%202.14
>> > >> should be taken up in short notice.
>> > >> Not sure if you are native speaker, but we also look for native
>> speakers
>> > >> to have a look at texts of others before pulling into the docs.
>> > >> Pick an issue, try something, ask... just DO it ;-)
>> > >> Regards,
>> > >> ps reaching me in private is best done via richard at qgis.org...
>> Using the
>> > >> rdmailings you end up in the big pile of mailinglists I have :-)
>> > >> BUT I prefer communicating through mailing lists as more people learn
>> > >> from this.
>> > >> _______________________________________________
>> > >> Qgis-community-team mailing list for organizing community resources
>> such
>> > >> as documentation, translation etc..
>> > >> Qgis-community-team at lists.osgeo.org
>> > >> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
>> > > Alexandre Neto
>> > > @AlexNetoGeo
>> > > http://sigsemgrilhetas.wordpress.com
>> > > http://gisunchained.wordpress.com
>> such
>> Qgis-community-team mailing list for organizing community resources such
> Alexandre Neto
> @AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20160604/e3322345/attachment-0001.html>
More information about the Qgis-community-team
