[Qgis-community-team] substition for |addBasicShape|
Martina Savarese martina.savarese at gmail.com
Tue Apr 16 05:48:31 PDT 2019
Hi, hope someone can give you a more correct suggestion cause my English is
not good enought and I did only small pr. Anyway, at the end of your rst
file you should have a list of icon substitution related to your file and
alphabetically ordered. You have to add your icon substitution there. There
is also a script to automatically insert it, but I've never used it.
Martina
Il Mar 16 Apr 2019 14:16 Larissa Junek <l.junek at gmx.net> ha scritto:
> Hello guys,
> can somebody help me with a substitution in my rst-file ?
> Working on the print composer I created an own rst-file for the chapter
> "Session for advanced users: Creating a Dynamic Map Layout"
> My text looks like this:
> <First step is that you insert a rectangle which will be the header with
> the |addBasicShape| :sup:`Add Shape` Item. >
> After running the make fasthtml command in the python virtual environment
> there is the icon missing, its not being transformed into a figure.
> |addBasicShape| is included in /source/substitutions.txt.
> Will I need to insert additional commands in my rst-file so that the
> substitution works?
> Cheers, Larissa
> Qgis-community-team mailing list for organizing community resources such
> as documentation, translation etc..
> Qgis-community-team at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20190416/4c88e1a4/attachment.html>
More information about the Qgis-community-team mailing list
