[Qgis-community-team] substition for |addBasicShape|
Alexandre Neto senhor.neto at gmail.com
Tue Apr 16 07:48:58 PDT 2019
Hi Larissa,
Like martina said, you need to either run the python script to make it
automatic, or you also need to add it manually at the bottom of the rst
file. I know it looks a bit cumbersome, but that's how we (I) was able to
make the images show on github.
Can you provide a link to your PR or branch that you are working?
Thanks
On Tue, Apr 16, 2019 at 1:48 PM Martina Savarese <martina.savarese at gmail.com>
wrote:
> Hi, hope someone can give you a more correct suggestion cause my English
> is not good enought and I did only small pr. Anyway, at the end of your rst
> file you should have a list of icon substitution related to your file and
> alphabetically ordered. You have to add your icon substitution there. There
> is also a script to automatically insert it, but I've never used it.
> Martina
> Il Mar 16 Apr 2019 14:16 Larissa Junek <l.junek at gmx.net> ha scritto:
>> Hello guys,
>> can somebody help me with a substitution in my rst-file ?
>> Working on the print composer I created an own rst-file for the chapter
>> "Session for advanced users: Creating a Dynamic Map Layout"
>> My text looks like this:
>> <First step is that you insert a rectangle which will be the header with
>> the |addBasicShape| :sup:`Add Shape` Item. >
>> After running the make fasthtml command in the python virtual environment
>> there is the icon missing, its not being transformed into a figure.
>> |addBasicShape| is included in /source/substitutions.txt.
>> Will I need to insert additional commands in my rst-file so that the
>> substitution works?
>> Cheers, Larissa
>> Qgis-community-team mailing list for organizing community resources such
>> as documentation, translation etc..
>> Qgis-community-team at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20190416/5863df62/attachment.html>
More information about the Qgis-community-team mailing list
