[Qgis-community-team] [Qgis-psc] Translating "The question of the Month" survey?
Anita Graser
anitagraser at gmx.at
Mon Feb 4 07:14:06 PST 2019
On Mon, Feb 4, 2019 at 3:08 PM Carlos Rivas <carlosrsuazo at gmail.com> wrote:
> Hi Anita and all, I do not have a list of plugins, and I only need to
> translate the question in this new file, by the way there is a new
> japanese label ready to translate: open
> <https://docs.google.com/spreadsheets/d/1k_qb_L5FlzdnufBQ5_3Wg0g_EpSanYa6CkQI57PxORM/edit?usp=sharing>
> The idea is that the survey will show the list of the plugins (there are
> almost 1000!) for Option1, Option 2 and Option 3 (if we go for 3 options,
> we can have as many as we want).
It's not quite that bad. There are 279 plugins for QGIS 3 that are marked
as stable. (If we also want to include experimental plugins, that would
make 341.)
You can copy the list from
https://plugins.qgis.org/plugins/plugins.xml?qgis=3.4 (left side of the
page). It contains a couple of duplicates, but shouldn't be too bad.
Regards,
Anita
> With the list, I can create a new form and implement today if necessary.
> Best wishes
> Carlos R.
> On Sun, Feb 3, 2019 at 12:10 PM Anita Graser <anitagraser at gmx.at> wrote:
>> That's an interesting idea but is it feasible to implement by tomorrow?
>> Usually we publish the question after the PSC meeting.
>> Carlos, do you already have a list of plugins or a plan how to get it? Or
>> do you need help with that?
>> Is there a spreadsheet for translation of the question?
>> "Which plugins should be listed as "featured" in the QGIS plugin
>> respository?"
>> How many nominations do we want to allow? 3? 5? more?
>> Regards,
>> Anita
>> On Tue, Jan 29, 2019 at 11:54 PM Carlos Rivas <carlosrsuazo at gmail.com>
>> wrote:
>>> Hi everyone, Paolo is right, maybe we can propose a classification so
>>> when the responder select one big group then the survey shows some plugins?
>>> In this way we will get an idea not only about most preferred plugins but
>>> also the group.
>>> Regards
>>> Carlos
>>> El ene. 29, 2019 12:32 PM, "Paolo Cavallini" <cavallini at faunalia.it>
>>> escribió:
>>>> Agreed, an important point. With almost 1k plugins it may be cumbersome
>>>> though.
>>>> Cheers.
>>>> Il 29 gennaio 2019 19:26:28 CET, Anita Graser <anitagraser at gmx.at> ha
>>>> scritto:
>>>>> Hi Carlos,
>>>>> I think it's fine to go ahead.
>>>>> On Wed, Jan 23, 2019, 20:56 Carlos Rivas <carlosrsuazo at gmail.com
>>>>>>> wrote:
>>>>>>>> Hi everyone. We can use a list of plugins and we just need to
>>>>>>>> translate the question in all languages that we are using.
>>>>> Do you need support for the list of plugins? It will make evaluating
>>>>> the results much easier if we can make sure that participants can only
>>>>> enter valid plugin names.
>>>>> Regards,
>>>>> Anita
>>>> Sorry for being short
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20190204/2f363e5c/attachment.html>
More information about the Qgis-community-team
