[Qgis-community-team] [Qgis-user] training manual QGIS 3
    Janneke van Dijk
    janneke.qgis at gmail.com
    Mon Jan  7 10:16:56 PST 2019
Yes, I would be up for learning how to do it. I remember once upon a
time trying to get started and somehow getting stranded before I got
anywhere. Partly because I couldn't get linux to work on VM on my laptop
so I couldn't do the screen shots.
On 07/01/2019 17:39, Alexandre Neto wrote:
> Some of those changes are quite small. Would you be interested in
> learning how to fix it yourself?
> A seg, 7/01/2019, 14:37, Alexandre Neto <senhor.neto at gmail.com
> <mailto:senhor.neto at gmail.com>> escreveu:
>     Actually, someone already did it. Thanks!!
>         I can do it.
>         A seg, 7/01/2019, 13:43, Janneke van Dijk
>         <janneke.qgis at gmail.com <mailto:janneke.qgis at gmail.com>> escreveu:
>             I've registered all that I've noticed, I just didn't
>             manage to tag them with training manual. Should I do that
>             or is that someone else who adds the labels?
>             Janneke
>             On 07/01/2019 00:42, Alexandre Neto wrote:
>>             Better duplicated issues than missing ones . So please
>>             report whatever you feel that is a bug, or a possible
>>             improvement. That way we won't forget.
>>             Thanks!
>>             A dom, 6/01/2019, 10:07, Janneke van Dijk
>>             escreveu:
>>                 Hi Harrissou,
>>                 Getting ready to at least list my observations. Do I
>>                 understand it correctly that whatever is not
>>                 mentioned in [2] is not being addressed? Quite a few
>>                 of my remarks will also related to updating
>>                 screenshots, which I think has also been mentioned as
>>                 a general issue somewhere - should I still list them
>>                 separately?
>>                 Thanks for your assistance,
>>                 Janneke
>>                 On 05/01/2019 13:33, DelazJ wrote:
>>>                 Hi Janneke,
>>>                 Thanks for your tests. And indeed the training
>>>                 manual update is a work in progress and maybe could
>>>                 you publish your remarks as issue reports in the doc
>>>                 repository [0] so that we took them into
>>>                 consideration as we go.
>>>                 You are right about the missing data, there was a
>>>                 pull request [1] to integrate these data we forgot
>>>                 to merge. Done now! Download the dataset again, please.
>>>                 Note that we are reviewing initial lessons and have
>>>                 some pending updates for both lessons [2] and
>>>                 corresponding data [3]. Tests and feedbacks are more
>>>                 than welcome. Thanks!
>>>                 [0] https://github.com/qgis/QGIS-Documentations/issues
>>>                 [1] https://github.com/qgis/QGIS-Training-Data/pull/15
>>>                 [2]
>>>                 https://github.com/qgis/QGIS-Documentation/pulls?q=is%3Apr+is%3Aopen+label%3A%22Training+Manual%22
>>>                 [3] https://github.com/qgis/QGIS-Training-Data/pull/17
>>>                 Regards,
>>>                 Harrissou
>>>                 Le jeu. 3 janv. 2019 à 13:22, Janneke van Dijk
>>>                 <mailto:janneke.qgis at gmail.com>> a écrit :
>>>                     Dear all,
>>>                       I'm currently going through the QGIS 3
>>>                     training manual
>>>                     (https://docs.qgis.org/testing/en/docs/training_manual/)
>>>                     using QGIS
>>>                     3.4.3 and documenting any changes that would
>>>                     still need attention. I
>>>                     understand that it's  a work in progress and
>>>                     hope/plan to contribute a
>>>                     bit in a later stage. What is complicating
>>>                     matters is that the data that
>>>                     I downloaded (QGIS-Training-Data-2.0.zip) does
>>>                     not contain all the
>>>                     layers that are mentioned (so far schools,
>>>                     restaurants, network_analysis
>>>                     folder and possibly some more that I may have
>>>                     skipped). Is there a
>>>                     complete/up-to-date data set available? Where
>>>                     can I find it?
>>>                     Thanks for any suggestions,
>>>                     Janneke
>>>                     _______________________________________________
>>>                     Qgis-user mailing list
>>>                     Qgis-user at lists.osgeo.org
>>>                     <mailto:Qgis-user at lists.osgeo.org>
>>>                     List info:
>>>                     https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>                     Unsubscribe:
>>                 Qgis-community-team mailing list for organizing
>>                 community resources such as documentation,
>>                 translation etc..
>>                 Qgis-community-team at lists.osgeo.org
>>                 <mailto:Qgis-community-team at lists.osgeo.org>
>>                 https://lists.osgeo.org/mailman/listinfo/qgis-community-team
>>             Alexandre Neto
>>             @AlexNetoGeo
>>             http://sigsemgrilhetas.wordpress.com
>>             http://gisunchained.wordpress.com
>         Alexandre Neto
>         @AlexNetoGeo
>     Alexandre Neto
>     @AlexNetoGeo
> Alexandre Neto
> @AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20190107/9ce49d42/attachment.html>
More information about the Qgis-community-team
