[Qgis-community-team] [Qgis-user] training manual QGIS 3
Alexandre Neto
senhor.neto at gmail.com
Mon Jan 7 12:27:00 PST 2019
Screenshots shouldn't be a blocker, you can take screenshots using windows.
Then, if we have time, we can replace windows screenshots later.
A seg, 7/01/2019, 18:17, Janneke van Dijk <janneke.qgis at gmail.com> escreveu:
> Yes, I would be up for learning how to do it. I remember once upon a time
> trying to get started and somehow getting stranded before I got anywhere.
> Partly because I couldn't get linux to work on VM on my laptop so I
> couldn't do the screen shots.
> On 07/01/2019 17:39, Alexandre Neto wrote:
> Some of those changes are quite small. Would you be interested in learning
> how to fix it yourself?
> A seg, 7/01/2019, 14:37, Alexandre Neto <senhor.neto at gmail.com> escreveu:
>> Actually, someone already did it. Thanks!!
>>> I can do it.
>>> A seg, 7/01/2019, 13:43, Janneke van Dijk <janneke.qgis at gmail.com>
>>> escreveu:
>>>> I've registered all that I've noticed, I just didn't manage to tag them
>>>> with training manual. Should I do that or is that someone else who adds the
>>>> labels?
>>>> Janneke
>>>> On 07/01/2019 00:42, Alexandre Neto wrote:
>>>> Better duplicated issues than missing ones . So please report whatever
>>>> you feel that is a bug, or a possible improvement. That way we won't forget.
>>>> Thanks!
>>>> A dom, 6/01/2019, 10:07, Janneke van Dijk <janneke.qgis at gmail.com>
>>>> escreveu:
>>>>> Hi Harrissou,
>>>>> Getting ready to at least list my observations. Do I understand it
>>>>> correctly that whatever is not mentioned in [2] is not being addressed?
>>>>> Quite a few of my remarks will also related to updating screenshots, which
>>>>> I think has also been mentioned as a general issue somewhere - should I
>>>>> still list them separately?
>>>>> Thanks for your assistance,
>>>>> Janneke
>>>>> On 05/01/2019 13:33, DelazJ wrote:
>>>>> Hi Janneke,
>>>>> Thanks for your tests. And indeed the training manual update is a work
>>>>> in progress and maybe could you publish your remarks as issue reports in
>>>>> the doc repository [0] so that we took them into consideration as we go.
>>>>> You are right about the missing data, there was a pull request [1] to
>>>>> integrate these data we forgot to merge. Done now! Download the dataset
>>>>> again, please.
>>>>> Note that we are reviewing initial lessons and have some pending
>>>>> updates for both lessons [2] and corresponding data [3]. Tests and
>>>>> feedbacks are more than welcome. Thanks!
>>>>> [0] https://github.com/qgis/QGIS-Documentations/issues
>>>>> [1] https://github.com/qgis/QGIS-Training-Data/pull/15
>>>>> [2]
>>>>> https://github.com/qgis/QGIS-Documentation/pulls?q=is%3Apr+is%3Aopen+label%3A%22Training+Manual%22
>>>>> [3] https://github.com/qgis/QGIS-Training-Data/pull/17
>>>>> Regards,
>>>>> Harrissou
>>>>> Le jeu. 3 janv. 2019 à 13:22, Janneke van Dijk <janneke.qgis at gmail.com>
>>>>> a écrit :
>>>>>> Dear all,
>>>>>> I'm currently going through the QGIS 3 training manual
>>>>>> (https://docs.qgis.org/testing/en/docs/training_manual/) using QGIS
>>>>>> 3.4.3 and documenting any changes that would still need attention. I
>>>>>> understand that it's a work in progress and hope/plan to contribute
>>>>>> a
>>>>>> bit in a later stage. What is complicating matters is that the data
>>>>>> that
>>>>>> I downloaded (QGIS-Training-Data-2.0.zip) does not contain all the
>>>>>> layers that are mentioned (so far schools, restaurants,
>>>>>> network_analysis
>>>>>> folder and possibly some more that I may have skipped). Is there a
>>>>>> complete/up-to-date data set available? Where can I find it?
>>>>>> Thanks for any suggestions,
>>>>>> Janneke
>>>>>> _______________________________________________
>>>>>> Qgis-user mailing list
>>>>>> Qgis-user at lists.osgeo.org
>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Qgis-community-team mailing list for organizing community resources
>>>>> such as documentation, translation etc..
>>>>> Qgis-community-team at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
>>>> Alexandre Neto
>>>> @AlexNetoGeo
>>>> http://sigsemgrilhetas.wordpress.com
>>>> http://gisunchained.wordpress.com
>>> Alexandre Neto
>>> @AlexNetoGeo
>> Alexandre Neto
>> @AlexNetoGeo
> Alexandre Neto
> @AlexNetoGeo
Alexandre Neto
@AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20190107/e8d000a1/attachment.html>
More information about the Qgis-community-team
