[Qgis-community-team] [Qgis-user] training manual QGIS 3
    Janneke van Dijk
    janneke.qgis at gmail.com
    Wed Jan  9 10:18:23 PST 2019
Hi Harrissou,
thanks for the quick intervention :-). Indeed, I did read about the
trap, but wasn't sure where I was supposed to encounter it. I've done it
again following your short description and that I think has worked...Let
me know if I am still supposed to press more buttons...I'll have a look
tomorrow at the guidelines and check why it wasn't obvious enough to me.
Good night,
Janneke
On 09/01/2019 21:01, DelazJ wrote:
> Hi Janneke,
> I guess you are talking about
> https://github.com/janneke-qgis/QGIS-Documentation/pull/1 which is
> unfortunately a pull-request against your own branch and not the
> upstream one. This is a trap we all fall in at the beginning and
> mentioned at
> https://docs.qgis.org/testing/en/docs/documentation_guidelines/first_contribution.html#share-your-changes-via-pull-request
> What you have to do is also explained in the page I linked above (if
> ever not clear, let us know, we'll try to improve it) but in short:
> 1. Go to https://github.com/qgis/QGIS-Documentation/pulls
> 2. Press "New pull request"
> 3. Click "Compare accross forks" and select your repo in the head fork
> drop down menu and then the your branch (janneke-qgis-patch-1 in this
> case)
> 4. Press "Create pull request"
> 5. And you are done!
> H.
> Le mer. 9 janv. 2019 à 18:46, Janneke van Dijk <janneke.qgis at gmail.com
> <mailto:janneke.qgis at gmail.com>> a écrit :
>     Hi Alexandre and Harrissou (and others),
>     I'm trying to feel my way through the contribution thing and
>     github by starting with some small remarks/changes I suggested
>     myself. I think I have just made an edit and created a pull
>     request - it tells me 'This branch has no conflicts with the base
>     branch'. Not sure how to proceed from here. Is this enough from my
>     side?
>     Thanks for some guidance....
>     Janneke
>     On 07/01/2019 23:27, Alexandre Neto wrote:
>>     Screenshots shouldn't be a blocker, you can take screenshots
>>     using windows. Then, if we have time, we can replace windows
>>     screenshots later.
>>     A seg, 7/01/2019, 18:17, Janneke van Dijk <janneke.qgis at gmail.com
>>     <mailto:janneke.qgis at gmail.com>> escreveu:
>>         Yes, I would be up for learning how to do it. I remember once
>>         upon a time trying to get started and somehow getting
>>         stranded before I got anywhere. Partly because I couldn't get
>>         linux to work on VM on my laptop so I couldn't do the screen
>>         shots.
>>         On 07/01/2019 17:39, Alexandre Neto wrote:
>>>         Some of those changes are quite small. Would you be
>>>         interested in learning how to fix it yourself?
>>>         A seg, 7/01/2019, 14:37, Alexandre Neto
>>>         <senhor.neto at gmail.com <mailto:senhor.neto at gmail.com>> escreveu:
>>>             Actually, someone already did it. Thanks!!
>>>             escreveu:
>>>                 I can do it.
>>>                 A seg, 7/01/2019, 13:43, Janneke van Dijk
>>>                     I've registered all that I've noticed, I just
>>>                     didn't manage to tag them with training manual.
>>>                     Should I do that or is that someone else who
>>>                     adds the labels?
>>>                     Janneke
>>>                     On 07/01/2019 00:42, Alexandre Neto wrote:
>>>>                     Better duplicated issues than missing ones . So
>>>>                     please report whatever you feel that is a bug,
>>>>                     or a possible improvement. That way we won't
>>>>                     forget.
>>>>                     Thanks!
>>>>                     A dom, 6/01/2019, 10:07, Janneke van Dijk
>>>>                         Hi Harrissou,
>>>>                         Getting ready to at least list my
>>>>                         observations. Do I understand it correctly
>>>>                         that whatever is not mentioned in [2] is
>>>>                         not being addressed? Quite a few of my
>>>>                         remarks will also related to updating
>>>>                         screenshots, which I think has also been
>>>>                         mentioned as a general issue somewhere -
>>>>                         should I still list them separately?
>>>>                         Thanks for your assistance,
>>>>                         Janneke
>>>>                         On 05/01/2019 13:33, DelazJ wrote:
>>>>>                         Hi Janneke,
>>>>>                         Thanks for your tests. And indeed the
>>>>>                         training manual update is a work in
>>>>>                         progress and maybe could you publish your
>>>>>                         remarks as issue reports in the doc
>>>>>                         repository [0] so that we took them into
>>>>>                         consideration as we go.
>>>>>                         You are right about the missing data,
>>>>>                         there was a pull request [1] to integrate
>>>>>                         these data we forgot to merge. Done now!
>>>>>                         Download the dataset again, please.
>>>>>                         Note that we are reviewing initial lessons
>>>>>                         and have some pending updates for both
>>>>>                         lessons [2] and corresponding data [3].
>>>>>                         Tests and feedbacks are more than welcome.
>>>>>                         Thanks!
>>>>>                         [0]
>>>>>                         https://github.com/qgis/QGIS-Documentations/issues
>>>>>                         [1]
>>>>>                         https://github.com/qgis/QGIS-Training-Data/pull/15
>>>>>                         [2]
>>>>>                         https://github.com/qgis/QGIS-Documentation/pulls?q=is%3Apr+is%3Aopen+label%3A%22Training+Manual%22
>>>>>                         [3]
>>>>>                         https://github.com/qgis/QGIS-Training-Data/pull/17
>>>>>                         Regards,
>>>>>                         Harrissou
>>>>>                         Le jeu. 3 janv. 2019 à 13:22, Janneke van
>>>>>                             Dear all,
>>>>>                               I'm currently going through the QGIS
>>>>>                             3 training manual
>>>>>                             (https://docs.qgis.org/testing/en/docs/training_manual/)
>>>>>                             using QGIS
>>>>>                             3.4.3 and documenting any changes that
>>>>>                             would still need attention. I
>>>>>                             understand that it's  a work in
>>>>>                             progress and hope/plan to contribute a
>>>>>                             bit in a later stage. What is
>>>>>                             complicating matters is that the data
>>>>>                             that
>>>>>                             I downloaded
>>>>>                             (QGIS-Training-Data-2.0.zip) does not
>>>>>                             contain all the
>>>>>                             layers that are mentioned (so far
>>>>>                             schools, restaurants, network_analysis
>>>>>                             folder and possibly some more that I
>>>>>                             may have skipped). Is there a
>>>>>                             complete/up-to-date data set
>>>>>                             available? Where can I find it?
>>>>>                             Thanks for any suggestions,
>>>>>                             Janneke
>>>>>                             _______________________________________________
>>>>>                             Qgis-user mailing list
>>>>>                             Qgis-user at lists.osgeo.org
>>>>>                             <mailto:Qgis-user at lists.osgeo.org>
>>>>>                             List info:
>>>>>                             https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>                             Unsubscribe:
>>>>                         Qgis-community-team mailing list for
>>>>                         organizing community resources such as
>>>>                         documentation, translation etc..
>>>>                         Qgis-community-team at lists.osgeo.org
>>>>                         <mailto:Qgis-community-team at lists.osgeo.org>
>>>>                         https://lists.osgeo.org/mailman/listinfo/qgis-community-team
>>>>                     Alexandre Neto
>>>>                     @AlexNetoGeo
>>>>                     http://sigsemgrilhetas.wordpress.com
>>>>                     http://gisunchained.wordpress.com
>>>                 Alexandre Neto
>>>                 @AlexNetoGeo
>>>             Alexandre Neto
>>>             @AlexNetoGeo
>>>         Alexandre Neto
>>>         @AlexNetoGeo
>>     Alexandre Neto
>>     @AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20190109/d8a19903/attachment-0001.html>
More information about the Qgis-community-team
