[Qgis-community-team] [Qgis-user] training manual QGIS 3
DelazJ
delazj at gmail.com
Wed Jan 9 10:36:15 PST 2019
Le mer. 9 janv. 2019 à 19:18, Janneke van Dijk <janneke.qgis at gmail.com> a
écrit :
> Hi Harrissou,
> thanks for the quick intervention :-).
You are welcome.
And it's all good; your pull request is at the right place. It's time for
reviewers, now!
> Indeed, I did read about the trap, but wasn't sure where I was supposed to
> encounter it. I've done it again following your short description and that
> I think has worked...Let me know if I am still supposed to press more
> buttons...I'll have a look tomorrow at the guidelines and check why it
> wasn't obvious enough to me.
> Good night,
> Janneke
> On 09/01/2019 21:01, DelazJ wrote:
> Hi Janneke,
> I guess you are talking about
> https://github.com/janneke-qgis/QGIS-Documentation/pull/1 which is
> unfortunately a pull-request against your own branch and not the upstream
> one. This is a trap we all fall in at the beginning and mentioned at
> https://docs.qgis.org/testing/en/docs/documentation_guidelines/first_contribution.html#share-your-changes-via-pull-request
> What you have to do is also explained in the page I linked above (if ever
> not clear, let us know, we'll try to improve it) but in short:
> 1. Go to https://github.com/qgis/QGIS-Documentation/pulls
> 2. Press "New pull request"
> 3. Click "Compare accross forks" and select your repo in the head fork
> drop down menu and then the your branch (janneke-qgis-patch-1 in this case)
> 4. Press "Create pull request"
> 5. And you are done!
> H.
> Le mer. 9 janv. 2019 à 18:46, Janneke van Dijk <janneke.qgis at gmail.com> a
> écrit :
>> Hi Alexandre and Harrissou (and others),
>> I'm trying to feel my way through the contribution thing and github by
>> starting with some small remarks/changes I suggested myself. I think I have
>> just made an edit and created a pull request - it tells me 'This branch
>> has no conflicts with the base branch'. Not sure how to proceed from here.
>> Is this enough from my side?
>> Thanks for some guidance....
>> Janneke
>> On 07/01/2019 23:27, Alexandre Neto wrote:
>> Screenshots shouldn't be a blocker, you can take screenshots using
>> windows. Then, if we have time, we can replace windows screenshots later.
>> A seg, 7/01/2019, 18:17, Janneke van Dijk <janneke.qgis at gmail.com>
>> escreveu:
>>> Yes, I would be up for learning how to do it. I remember once upon a
>>> time trying to get started and somehow getting stranded before I got
>>> anywhere. Partly because I couldn't get linux to work on VM on my laptop so
>>> I couldn't do the screen shots.
>>> On 07/01/2019 17:39, Alexandre Neto wrote:
>>> Some of those changes are quite small. Would you be interested in
>>> learning how to fix it yourself?
>>> A seg, 7/01/2019, 14:37, Alexandre Neto <senhor.neto at gmail.com>
>>> escreveu:
>>>> Actually, someone already did it. Thanks!!
>>>> escreveu:
>>>>> I can do it.
>>>>> A seg, 7/01/2019, 13:43, Janneke van Dijk <janneke.qgis at gmail.com>
>>>>> escreveu:
>>>>>> I've registered all that I've noticed, I just didn't manage to tag
>>>>>> them with training manual. Should I do that or is that someone else who
>>>>>> adds the labels?
>>>>>> Janneke
>>>>>> On 07/01/2019 00:42, Alexandre Neto wrote:
>>>>>> Better duplicated issues than missing ones . So please report
>>>>>> whatever you feel that is a bug, or a possible improvement. That way we
>>>>>> won't forget.
>>>>>> Thanks!
>>>>>> A dom, 6/01/2019, 10:07, Janneke van Dijk <janneke.qgis at gmail.com>
>>>>>> escreveu:
>>>>>>> Hi Harrissou,
>>>>>>> Getting ready to at least list my observations. Do I understand it
>>>>>>> correctly that whatever is not mentioned in [2] is not being addressed?
>>>>>>> Quite a few of my remarks will also related to updating screenshots, which
>>>>>>> I think has also been mentioned as a general issue somewhere - should I
>>>>>>> still list them separately?
>>>>>>> Thanks for your assistance,
>>>>>>> Janneke
>>>>>>> On 05/01/2019 13:33, DelazJ wrote:
>>>>>>> Hi Janneke,
>>>>>>> Thanks for your tests. And indeed the training manual update is a
>>>>>>> work in progress and maybe could you publish your remarks as issue reports
>>>>>>> in the doc repository [0] so that we took them into consideration as we go.
>>>>>>> You are right about the missing data, there was a pull request [1]
>>>>>>> to integrate these data we forgot to merge. Done now! Download the dataset
>>>>>>> again, please.
>>>>>>> Note that we are reviewing initial lessons and have some pending
>>>>>>> updates for both lessons [2] and corresponding data [3]. Tests and
>>>>>>> feedbacks are more than welcome. Thanks!
>>>>>>> [0] https://github.com/qgis/QGIS-Documentations/issues
>>>>>>> [1] https://github.com/qgis/QGIS-Training-Data/pull/15
>>>>>>> [2]
>>>>>>> https://github.com/qgis/QGIS-Documentation/pulls?q=is%3Apr+is%3Aopen+label%3A%22Training+Manual%22
>>>>>>> [3] https://github.com/qgis/QGIS-Training-Data/pull/17
>>>>>>> Regards,
>>>>>>> Harrissou
>>>>>>> Le jeu. 3 janv. 2019 à 13:22, Janneke van Dijk <
>>>>>>> janneke.qgis at gmail.com> a écrit :
>>>>>>>> Dear all,
>>>>>>>> I'm currently going through the QGIS 3 training manual
>>>>>>>> (https://docs.qgis.org/testing/en/docs/training_manual/) using
>>>>>>>> QGIS
>>>>>>>> 3.4.3 and documenting any changes that would still need attention.
>>>>>>>> I
>>>>>>>> understand that it's a work in progress and hope/plan to
>>>>>>>> contribute a
>>>>>>>> bit in a later stage. What is complicating matters is that the data
>>>>>>>> that
>>>>>>>> I downloaded (QGIS-Training-Data-2.0.zip) does not contain all the
>>>>>>>> layers that are mentioned (so far schools, restaurants,
>>>>>>>> network_analysis
>>>>>>>> folder and possibly some more that I may have skipped). Is there a
>>>>>>>> complete/up-to-date data set available? Where can I find it?
>>>>>>>> Thanks for any suggestions,
>>>>>>>> Janneke
>>>>>>>> _______________________________________________
>>>>>>>> Qgis-user mailing list
>>>>>>>> Qgis-user at lists.osgeo.org
>>>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>> Qgis-community-team mailing list for organizing community resources
>>>>>>> such as documentation, translation etc..
>>>>>>> Qgis-community-team at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
>>>>>> Alexandre Neto
>>>>>> @AlexNetoGeo
>>>>>> http://sigsemgrilhetas.wordpress.com
>>>>>> http://gisunchained.wordpress.com
>>>>> Alexandre Neto
>>>>> @AlexNetoGeo
>>>> Alexandre Neto
>>>> @AlexNetoGeo
>>> Alexandre Neto
>>> @AlexNetoGeo
>> Alexandre Neto
>> @AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20190109/c3bae363/attachment-0001.html>
More information about the Qgis-community-team
