[Qgis-community-team] [QGIS-Developer] QGIS documentation build is failing and is making me crazy. Heeellp!!!!
Alexandre Neto
senhor.neto at gmail.com
Wed Jun 26 09:48:56 PDT 2019
Fingers crossed!!
https://github.com/qgis/QGIS-Documentation/pull/3888
A qua, 26/06/2019, 12:05, DelazJ <delazj at gmail.com> escreveu:
> Hi,
> OK. Thanks Alex. Looking forward.
> Meanwhile, I came accross some global variables
> https://www.sphinx-doc.org/en/master/usage/extensions/doctest.html#configuration
> Cheers,
> Harrissou
> Le mer. 26 juin 2019 à 11:59, Alexandre Neto <senhor.neto at gmail.com> a
> écrit :
>> Hi Harrissou,
>> I think you are over thinking it. We don't need to revert everything, We
>> just need to make sure that certain variables are initialized or fully
>> replaced in each rst file to be tested. For example, if we have a project
>> instance where layers are added in different rst files, it will be hard to
>> guess the status of that project everytime.
>> I will try to have a look at it later. I am not an experienced PyQGIS
>> guy, but I think I can stab it.
>> Thanks,
>> Alex
>> On Wed, Jun 26, 2019 at 8:50 AM matteo <matteo.ghetta at gmail.com> wrote:
>>> Same here. Ran locally and no failures
>>> Matteo
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20190626/6d7b7550/attachment.html>
More information about the Qgis-community-team
