[Qgis-community-team] Moving static folder back in source again?
Alexandre Neto
senhor.neto at gmail.com
Sun Mar 17 08:33:03 PDT 2019
>From this question, it seems that xcopy may do what we need:
https://stackoverflow.com/questions/26243865/sync-two-folders-using-batch-file
xcopy /s /d <Original Folder> <Destination Folder>
Alexandre Neto <senhor.neto at gmail.com> escreveu no dia domingo, 17/03/2019
às 15:27:
> (temporarily?) kinda of, the folder should be ignored in git, but the
> files can be there for later usage.
> (Back?) why would we need to move them back?
> For windows we can use something different than rsync, a plain copy should
> do. The advantage of rsync is that it will only copy the files if they are
> new or have been changed, which does not trigger sphinx to rebuild
> everything every single time. (That is why building Docs is not quite fast)
> Richard 🌍 Duivenvoorde <richard at duif.net> escreveu no dia domingo,
> 17/03/2019 às 14:58:
>> On 17/03/2019 15.13, Alexandre Neto wrote:
>> > I need to recheck, but the reason behind where the static folder is
>> > located has to do with the images preview on github. But we could get a
>> > way to make it work both on makefile and make.bat
>> Sigh,... yes I see you are right...
>> And if I try to point to /source/static/common or source/static/common
>> for the images then Sphinx cannot find them :(
>> Best indeed to keep it as is and eventually fix the make.bat file to
>> (temporarily?) move the static from the root to the source file (and
>> back?)
>> Richard
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
Alexandre Neto
@AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20190317/3febbb27/attachment.html>
More information about the Qgis-community-team
