[Qgis-community-team] QGIS docs: Vanilla build & ReadTheDocs theme
Anita Graser anitagraser at gmx.at
Sat May 25 10:39:41 PDT 2019
Hi Richard,
I think the ReadTheDocs theme is a huge improvement. Just comparing
https://docs.qgis.org/testing/en/docs/pyqgis_developer_cookbook/loadlayer.html
to https://qgis.org/test/en/docs/pyqgis_developer_cookbook/loadlayer.html
shows how much more readable the code samples are.
Are there any blockers to rolling it out?
Regards,
Anita
On Mon, Mar 18, 2019 at 6:23 PM Alexandre Neto <senhor.neto at gmail.com>
wrote:
> That is good to know. we should had that xcode information to our writing
> guidelines and Readme.
> Alex
> A seg, 18/03/2019, 16:40, Ian Maddaus <maddaus at protonmail.com> escreveu:
>> I've successfully built the new documentation using a Mac. A Mac user
>> would have to install Xcode but that's not a big problem.
>> ‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
>> On Monday, March 18, 2019 7:40 AM, Alexandre Neto <senhor.neto at gmail.com>
>> wrote:
>> Sounds good to me.
>> IIRC, The docs split was not related to the PyCookbook testing. We can
>> run tests on them as they are.
>> The split would just remove some of the static stuff the guidelines. We
>> don't need guideline for different versions. And even the Gentle
>> introduction to GIS, that could be version, we are not updating it
>> regularly, but we have it replicated for each version of QGIS we release.
>> On Mon, Mar 18, 2019 at 11:35 AM Richard Duivenvoorde <
>> rdmailings at duif.net> wrote:
>>> On 2019-03-18 09:13, Alexandre Neto wrote:
>>> > Hi, I would refrain to change the looks of it right away.
>>> > I also have my list of improvements for that, but I think it would be
>>> > better to stabilize the usage of the theme and it's options first, and
>>> > then do the improvements on top of that.
>>> +1
>>> > Besides, you probably know that already, but there's a way to separate
>>> > our theme tweaks from the original read the docs theme. We really need
>>> > to do it the right way so we can update the theme whenever we need.
>>> > Related subject: we talked about splitting the QGIS docs content. Will
>>> > we keep using sphinx for the static content?
>>> > If so, and assuming we are going to use the same theme, it would be
>>> > better to share it via submodele, otherwise, any theme tweak must be
>>> > replicated twice.
>>> Yes, but (to me) one reason to split was because I thought to make the
>>> python cookbook testable it would be better.
>>> I'm still ok to split (in QGIS version specific and non version specific
>>> docs), but the immidiate need to me is over now (as we do it now it is
>>> just a rather quick and easy build?).
>>> I'd like to:
>>> - move to the rtd theme
>>> - make translations sync work
>>> - handle the windows build to work good with make.bat (so some static
>>> copying)
>>> But can be done in steps too
>>> Richard
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
> Qgis-community-team mailing list for organizing community resources such
> as documentation, translation etc..
> Qgis-community-team at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20190525/200d4d8a/attachment.html>
More information about the Qgis-community-team mailing list
