[Qgis-community-team] Fwd: QGIS installation error from own build
Sachin Kumar
surveykshak at gmail.com
Wed Apr 22 10:24:57 PDT 2020
---------- Forwarded message ---------
Date: Wed 22 Apr, 2020, 9:41 PM
Subject: QGIS installation error from own build
To: <qgis-developer at lists.osgeo.org>, <qgis-user at lists.osgeo.org>, <
qgis-community-team at lists.osgeo.org>
I am building *QGIS 3.10.5* on Windows 10 Pro and Visual Studio 2015.
Everything is going right and solution build successful and installed in
OSGeo4W/apps/qgis-test folder. After that I had run perl creatensis.pl in
command prompt and it create a package with name
*“QGIS-OSGeo4W-3.10.5-1-Setup-x86_64”* with is default download, which run
successful after installation.
When I copied my build files from qgis-test folder to
“..\ms-windows\osgeo4w\unpacked-x86_64\apps\qgis” and copied
“OSGeo4W/apps/qgis-test/bin/qgis.exe” to
“..\ms-windows\osgeo4w\unpacked-x86_64\bin and rename *qgis.exe*to
*qgis-bin*”. After that run perl creatensis.pl I get
“QGIS-OSGeo4W-3.10.5-2-Setup-x86_64.exe”.
After installation I get following error:
Error loading QGIS
Oops, looks like an error loading QGIS
Details:
Could not load qgis_app.dll
Windows Error: The specified module could not be found.
Help:
Check C:\Program Files\QGIS 3.10\bin\qgis-bin.env for correct environment
paths
[image: error.PNG]
Earlier I also get the same error hence I format my system and install
fresh Window 10 Pro, but now again I am getting the same error. Is there
any bug during packaging? Any solution
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20200422/c95a248e/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20200422/c95a248e/attachment.png>
More information about the Qgis-community-team
