[Qgis-community-team] Fwd: [Qgis-user] documentation v 3.10 - PDF ?
Alexandre Neto
senhor.neto at gmail.com
Fri Apr 24 00:15:26 PDT 2020
Something to discuss?
---------- Forwarded message ---------
De: Håvard Tveite <havard.tveite at nmbu.no>
Date: quinta, 23/04/2020, 22:20
Subject: Re: [Qgis-user] documentation v 3.10 - PDF ?
To: Alexandre Neto <senhor.neto at gmail.com>, karsten <karsten at terragis.net>
Cc: QGIS User <qgis-user at lists.osgeo.org>
I hope that we can continue to provide the documentation also
as PDFs (one for the user manual, one for the training manual, ...).
HTML definitely has its merits, but I find a PDF very much more
convenient than a huge structure of HTML files for reading and
searching the documentation.
Could a "compromise" be to generate the PDF(s) as a separate
process? We could then generate the PDFs less frequently
(and provide a warning about that).
Håvard
On 23.04.2020 23:09, Alexandre Neto wrote:
> Hello Karsten,
> The documentation team decided to drop the PDF creation, because It was
> a big overhead in the all process.
> The plan is to provide the HTML version in a zip package instead, but we
> were not able to tackle that yet. We think the HTML package will replace
> the PDF functionality, while providing another advantage. Having a local
> copy of the HTML, one can set QGIS to use it as an alternative to online
> documentation. That way, if you press a help button while offline, it
> will redirect to you local copy.
> Thanks,
> Alexandre Neto
> A quinta, 23/04/2020, 19:26, karsten <karsten at terragis.net
> <mailto:karsten at terragis.net>> escreveu:
> __
> Dear all,
> I have looked at the nice new documentation for QGIS v. 3.10 online
> (HTML) but wanted to find the PDF versions which unfortunately I
> could not locate so far (last ones I found are 3.4 ).
> Can someone point me to the doc PDFs ?
> or are there none available (unless I would install all the docs
> source code and try to compile them myself as PDF ) ?
> Thanks + Cheers
> Karsten
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20200424/b8993c55/attachment.html>
More information about the Qgis-community-team
