[Qgis-community-team] Move documentation guidelines to Website
Alexandre Neto
senhor.neto at gmail.com
Fri Jan 3 05:24:20 PST 2020
In that case, I will wait for more work on the vanilla sphinx.
I already put some time on it, but I plan to do more. Harrissou, as soon as
you have something mergeble, please do it so we can work together without
steping each other toes.
Let's also talk about the way we want the guidelines to be. To me it would
make sense for it to be inside the get involved section with a link in the
docs and in the README file.
Thanks,
Alex
A quinta, 2/01/2020, 17:23, DelazJ <delazj at gmail.com> escreveu:
> Hi Alexandre,
> Thanks for taking care of this.
> I'm OK with detaching the static docs from our doc release mechanism. But
> i'm really unsure whether the website is the right place for them.
> I regularly feel lost when I browse our website. I personally find it
> crowded, hard to guess under which header i can find an information, and
> I'm not sure that moving these docs will not just... hide them among tons
> of other things --> conclusion,: QGIS website needs more love, cleanup
> first (or a split? but this is not the topic here although...)
> I think the static docs deserve to be close to the release-based
> documentation, as they share more together: I think they should be listed
> at https://www.qgis.org/en/docs/index.html and should use the same theme
> as the docs. So i think, if they have to move to another repository, maybe
> a new repo based on the doc's one. This means that we should maybe postpone
> the split, update docs sphinx thingies first and then extracts folders of
> interest to that "duplicate" repository. The hard work would be done in the
> docs repo and all is about fixing references.
> If we go that way, the next point would be which name, url to use to
> publish these docs... no idea!
> I don't know whether I've been helpful here but...
> Regards,
> Harrissou
> Le jeu. 2 janv. 2020 à 18:09, Paolo Cavallini <cavallini at faunalia.it> a
> écrit :
>> Thanks Alexandre for this. I'd be in favour of take this chance to
>> converge towards a simple, more vanilla sphinx structure, if possible.
>> Cheers.
>> Il 02/01/20 01:08, Alexandre Neto ha scritto:
>> > Hi everyone,
>> > I have started working on reducing the QGIS-Documentation "docs".
>> > "My" idea would be to remove any static documents, that is, any document
>> > that doesn't really change with a new version of QGIS.
>> > I am starting with the Documentation Guidelines. Unfortunately, the move
>> > is not as simple as copy-pasting some folder from one repo to another.
>> > That's because the two sphinx project uses different extensions, folder
>> > structure, etc...
>> > So, before I carry on with it, I wanted to know if there are any
>> > objections to the move.
>> > Next, it would be the developers guide.
>> > Thanks,
>> > Alexandre Neto
>> > _______________________________________________
>> > Qgis-community-team mailing list for organizing community resources
>> such as documentation, translation etc..
>> > Qgis-community-team at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/qgis-community-team
>> Paolo Cavallini - www.faunalia.eu
>> QGIS.ORG Chair:
>> http://planet.qgis.org/planet/user/28/tag/qgis%20board/
>> Qgis-community-team mailing list for organizing community resources such
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20200103/8d7d8e50/attachment.html>
More information about the Qgis-community-team
