[Qgis-community-team] Fwd: Missing file
Richard Duivenvoorde
rdmailings at duif.net
Sat May 9 03:06:02 PDT 2020
We have some dataset for the training manual. If I am right they can be
found here:
https://github.com/qgis/QGIS-Training-Data/tree/master/exercise_data
The link in current master version of doc points to a v2.0 branch zip:
https://github.com/qgis/QGIS-Training-Data/archive/v2.0.zip
In the mail below somebody is missing some data for the
'forestry'-chapter. It was found and I'm thinking about just pushing the
whole forestry-directory in the master branch.
BUT: that is not the v2.0 zip....
So I propose to: create branches in this repository in line with the
QGIS-(documentation) branches.
So: a master branch (for current testing/master documentation), and a
release_3.4 and release_3.10 branch for the LTR docs). In that way the
excersice data can grow/shring along with changes in the training
manual, and people always have the right set with the right
documentation version (as the download url can be created including the
branch name like the archive url above).
Anybody has a problem with that?
We had some different places earlier to download the data. We had
data.osgeo.org/qgis and qgis.org/downloads. We/I then decided to make
qgis.org/download to be the canonical/leading one...
There: https://qgis.org/downloads/data/
is ALSO a training manual excercise data and THAT one contains a
'forestry' folder :-)
Another observation:
https://docs.qgis.org/3.10/en/docs/user_manual/introduction/getting_started.html#downloading-sample-data
Points to https://qgis.org/downloads/data/ where the data is zipped on
our qgis.org server.
What about putting that data also (versioned) in the same(?) git(hub)
repo: QGIS-excercise-data or else a different one:
QGIS-documentation-data so we can version it too (and also update it
easier....)
Any input?
Regards,
-------- Forwarded Message --------
Subject: Re: Missing file
Date: Tue, 5 May 2020 10:06:47 +0200
To: Antoine Yassa <ayassa at hotmail.com>, psc at qgis.org <psc at qgis.org>
CC: matteo <matteo.ghetta at gmail.com>, Paolo Cavallini
<cavallini at faunalia.it>
Hi Antoine,
Jürgen found your data :-)
Before having that data on Github, we had a download area:
in
https://qgis.org/downloads/data/training_manual_exercise_data.zip
is everything you need \o/ for the missing forestry chapter
@matteo @paolo: you both have worked on the training manual and its data
isn't it? In the zip there are files which are NOT on github...
Should I just add the forestry directory to it?
There is also:
https://github.com/qgis/QGIS-Training-Data/issues/21
of which I'm not sure if it is removed because the exercise is removed
or for another reason. Apparently it is available in an older zip
Probably best to have different branches for the Excercise data?
Like a 3.4, 3.10 and master branch?
Then in the different training manual versions point to the download-zip
of that branch?
Regards,
On 5/4/20 12:20 PM, Antoine Yassa wrote:
> Thanks Richard,
> That was my plan B. To use any other map in my area to geo-reference it.
> I was just trying to follow the training with just so well done database
> and good visual examples.
> Thanks again for a quick response.
> Regards,
> *𓋞**/Antoine Yassa/*
> Rouyn (819) 768-3000
> Cellular (819) 279-3000
> E-mail:__ayassa at hotmail.com <mailto:ayassa at hotmail.com>
> Uplink: https://www.hightail.com/u/AntoineYassa
> *This e-mail transmission is intended for the addressee indicated above.
> It may contain information that is privileged, confidential or otherwise
> protected from disclosure. Any review, dissemination or use of this
> transmission or its contents by persons other than the addressee is
> strictly prohibited. If you have received this e-mail in error, please
> immediately notify Sender by return e-mail or by phone at 819-279-3000.*
> *Ce courrier électronique et ses pièces jointes sont transmis en toute
> confidentialité pour l'utilisation de personne(s) à laquelle il est
> adressé et peut contenir des renseignements qui sont confidentiels ou
> exempts de divulgation. Toute utilisation non conforme ou duplication
> par des personnes autres que les destinataires sont formellement
> interdites. Si vous avez reçu ce message par erreur, notifiez s'il vous
> plait l'expéditeur (courriel ou 819-279-3000) et supprimez le fichier.*
> -----Original Message-----
> From: Richard 🌍Duivenvoorde <richard at duif.net>
> Sent: 4 May, 2020 02:33
> To: Antoine Yassa <ayassa at hotmail.com>; psc at qgis.org
> I searched in github too, but cannot find it.
> Apparently it has never been there?
> The original author was 'egonzale' 6 years ago... Anybody a pointer?
> Or else: you can do the excercise with a screenshot of some aerial too.
> Regards,
> On 5/3/20 10:53 PM, Antoine Yassa wrote:
>> Good Morning,
>> With the pandemic, I decided to improve myself and I got involved with
>> QGIS. I downloaded version 3.12 and have been following the training.
>> Unfortunately, the training exercise folder is missing a subfolder,
>> */_exercise_data/forestry_/* folder with the tif file
>> */_rautjarvi_map.tif_/*
>> */_ _/*
>> I searched everywhere and even downloaded another training exercise
>> folder: */qgis_sample_data/* without success to locate the raster file
>> */rautjarvi_map.tif/*.
>> Any chance I can obtain that file to complete the exercise?
>> Regards,
>> MINERAL*/Antoine Yassa/*
>> E-mail:___ayassa at hotmail.com <mailto:ayassa at hotmail.com>_
>> Uplink:
>> https://nam03.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.
>> hightail.com%2Fu%2FAntoineYassa&data=02%7C01%7C%7C4a3a117dd83447ec
>> aefb08d7eff5002d%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C63724170
>> 7859724311&sdata=EqaZvobXG0KIw8mZnhr7wWsBq5m0C7NrZh6pMYJtzDQ%3D&am
>> p;reserved=0
>> otherwise protected from disclosure. Any review, dissemination or use
>> of this transmission or its contents by persons other than the
>> addressee is strictly prohibited. If you have received this e-mail in
>> error, please immediately notify Sender by return e-mail or by phone
>> at 819-279-3000.*
>> confidentialité pour l'utilisation de, et/ou des personne(s) à
>> laquelle il est adressé et peut contenir des renseignements qui sont
>> confidentiels ou exempts de divulgation. Toute utilisation non
>> conforme ou duplication par les personnes autres que le(s)
>> destinataire(s) sont formellement interdites. Si vous avez reçu ce
>> message par erreur, notifiez s'il vous plait l'expéditeur (courriel ou
More information about the Qgis-community-team
