[Qgis-community-team] Missing file
Tim Sutton
tim at kartoza.com
Sat May 9 10:35:18 PDT 2020
Hi
> On 9 May 2020, at 11:06, Richard Duivenvoorde <rdmailings at duif.net> wrote:
> We have some dataset for the training manual. If I am right they can be
> found here:
> https://github.com/qgis/QGIS-Training-Data/tree/master/exercise_data
> The link in current master version of doc points to a v2.0 branch zip:
> https://github.com/qgis/QGIS-Training-Data/archive/v2.0.zip
> In the mail below somebody is missing some data for the
> 'forestry'-chapter. It was found and I'm thinking about just pushing the
> whole forestry-directory in the master branch.
> BUT: that is not the v2.0 zip....
> So I propose to: create branches in this repository in line with the
> QGIS-(documentation) branches.
> So: a master branch (for current testing/master documentation), and a
> release_3.4 and release_3.10 branch for the LTR docs). In that way the
> excersice data can grow/shring along with changes in the training
> manual, and people always have the right set with the right
> documentation version (as the download url can be created including the
> branch name like the archive url above).
> Anybody has a problem with that?
Sounds like a good idea!
> We had some different places earlier to download the data. We had
> data.osgeo.org/qgis and qgis.org/downloads. We/I then decided to make
> qgis.org/download to be the canonical/leading one...
> There: https://qgis.org/downloads/data/
> is ALSO a training manual excercise data and THAT one contains a
> 'forestry' folder :-)
> Another observation:
> https://docs.qgis.org/3.10/en/docs/user_manual/introduction/getting_started.html#downloading-sample-data
> Points to https://qgis.org/downloads/data/ where the data is zipped on
> our qgis.org server.
> What about putting that data also (versioned) in the same(?) git(hub)
> repo: QGIS-excercise-data or else a different one:
> QGIS-documentation-data so we can version it too (and also update it
> easier....)
I wonder if we can’t just manage the exercise data straight out of GitHub? It takes the strain off our infrastructure and can done to match the version of the docs / branch.
Regards
Tim
> Any input?
> Regards,
> -------- Forwarded Message --------
> Subject: Re: Missing file
> Date: Tue, 5 May 2020 10:06:47 +0200
> From: Richard 🌍 Duivenvoorde <richard at duif.net>
> To: Antoine Yassa <ayassa at hotmail.com>, psc at qgis.org <psc at qgis.org>
> CC: matteo <matteo.ghetta at gmail.com>, Paolo Cavallini
> <cavallini at faunalia.it>
> Hi Antoine,
> Jürgen found your data :-)
> Before having that data on Github, we had a download area:
> in
> https://qgis.org/downloads/data/training_manual_exercise_data.zip
> is everything you need \o/ for the missing forestry chapter
> @matteo @paolo: you both have worked on the training manual and its data
> isn't it? In the zip there are files which are NOT on github...
> Should I just add the forestry directory to it?
> There is also:
> https://github.com/qgis/QGIS-Training-Data/issues/21
> of which I'm not sure if it is removed because the exercise is removed
> or for another reason. Apparently it is available in an older zip
> Probably best to have different branches for the Excercise data?
> Like a 3.4, 3.10 and master branch?
> Then in the different training manual versions point to the download-zip
> of that branch?
> Regards,
> On 5/4/20 12:20 PM, Antoine Yassa wrote:
>> Thanks Richard,
>> That was my plan B. To use any other map in my area to geo-reference it.
>> I was just trying to follow the training with just so well done database
>> and good visual examples.
>> Thanks again for a quick response.
>> Regards,
>> *𓋞**/Antoine Yassa/*
>> Rouyn (819) 768-3000
>> Cellular (819) 279-3000
>> E-mail:__ayassa at hotmail.com <mailto:ayassa at hotmail.com>
>> Uplink: https://www.hightail.com/u/AntoineYassa
>> *This e-mail transmission is intended for the addressee indicated above.
>> It may contain information that is privileged, confidential or otherwise
>> protected from disclosure. Any review, dissemination or use of this
>> transmission or its contents by persons other than the addressee is
>> strictly prohibited. If you have received this e-mail in error, please
>> immediately notify Sender by return e-mail or by phone at 819-279-3000.*
>> *Ce courrier électronique et ses pièces jointes sont transmis en toute
>> confidentialité pour l'utilisation de personne(s) à laquelle il est
>> adressé et peut contenir des renseignements qui sont confidentiels ou
>> exempts de divulgation. Toute utilisation non conforme ou duplication
>> par des personnes autres que les destinataires sont formellement
>> interdites. Si vous avez reçu ce message par erreur, notifiez s'il vous
>> plait l'expéditeur (courriel ou 819-279-3000) et supprimez le fichier.*
>> -----Original Message-----
>> From: Richard 🌍Duivenvoorde <richard at duif.net>
>> Sent: 4 May, 2020 02:33
>> To: Antoine Yassa <ayassa at hotmail.com>; psc at qgis.org
>> I searched in github too, but cannot find it.
>> Apparently it has never been there?
>> The original author was 'egonzale' 6 years ago... Anybody a pointer?
>> Or else: you can do the excercise with a screenshot of some aerial too.
>> Regards,
>> On 5/3/20 10:53 PM, Antoine Yassa wrote:
>>> Good Morning,
>>> With the pandemic, I decided to improve myself and I got involved with
>>> QGIS. I downloaded version 3.12 and have been following the training.
>>> Unfortunately, the training exercise folder is missing a subfolder,
>>> */_exercise_data/forestry_/* folder with the tif file
>>> */_rautjarvi_map.tif_/*
>>> */_ _/*
>>> I searched everywhere and even downloaded another training exercise
>>> folder: */qgis_sample_data/* without success to locate the raster file
>>> */rautjarvi_map.tif/*.
>>> Any chance I can obtain that file to complete the exercise?
>>> Regards,
>>> MINERAL*/Antoine Yassa/*
>>> E-mail:___ayassa at hotmail.com <mailto:ayassa at hotmail.com>_
>>> Uplink:
>>> https://nam03.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.
>>> hightail.com%2Fu%2FAntoineYassa&data=02%7C01%7C%7C4a3a117dd83447ec
>>> aefb08d7eff5002d%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C63724170
>>> 7859724311&sdata=EqaZvobXG0KIw8mZnhr7wWsBq5m0C7NrZh6pMYJtzDQ%3D&am
>>> p;reserved=0
>>> otherwise protected from disclosure. Any review, dissemination or use
>>> of this transmission or its contents by persons other than the
>>> addressee is strictly prohibited. If you have received this e-mail in
>>> error, please immediately notify Sender by return e-mail or by phone
>>> at 819-279-3000.*
>>> confidentialité pour l'utilisation de, et/ou des personne(s) à
>>> laquelle il est adressé et peut contenir des renseignements qui sont
>>> confidentiels ou exempts de divulgation. Toute utilisation non
>>> conforme ou duplication par les personnes autres que le(s)
>>> destinataire(s) sont formellement interdites. Si vous avez reçu ce
>>> message par erreur, notifiez s'il vous plait l'expéditeur (courriel ou
> Qgis-community-team mailing list for organizing community resources such as documentation, translation etc..
> Qgis-community-team at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
Tim Sutton
Co-founder: Kartoza
Ex Project chair: QGIS.org
Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
Desktop GIS programming services
Geospatial web development
GIS Training
Consulting Services
Skype: timlinux
IRC: timlinux on #qgis at freenode.net
I'd love to connect. Here's my calendar link <https://calendly.com/timlinux/30min> to make finding time easy.
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20200509/5261bb0c/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20200509/5261bb0c/attachment-0001.jpg>
More information about the Qgis-community-team
