[Qgis-community-team] Testing documentation translation
DelazJ
delazj at gmail.com
Tue Sep 22 13:06:36 PDT 2020
Hi Richard,
Thanks for confirmation.
About 3.10 backports, I agree with you, and Alexandre opened a discussion
[0] a month ago but unfortunately that got no attention.
About 3.16 docs, not sure what you meant (if different from the points
raised in that discussion)
[0]
http://qgis-community-team.2324516.n4.nabble.com/Qgis-community-team-LTR-Documentation-soft-freeze-and-plans-for-the-future-td3377.html
Regards,
H.
Le mar. 22 sept. 2020 à 21:57, Richard Duivenvoorde <rdmailings at duif.net> a
écrit :
> On 9/22/20 2:48 PM, DelazJ wrote:
> > @Richard Duivenvoorde Can you please confirm that for someone with
> sufficient rights (I do!), instructions at
> https://github.com/qgis/QGIS-Documentation#translating are uptodate and
> help to load changes to transifex? That way, we can share the workload.
> > And if you don't have time to do the update, I can handle it later today.
> Hi Harrissou,
> I had to check (and by checking I also did it :-) ).
> But yes, I can confirm that, using the venv, the instructions are just
> fine \o/
> As said: new sources are pushed to transifex, so happy translating !
> One note: the rather big changes in files of 3.10 (because of the
> backporting) is an exception now.
> In normal scenario's there will not be such big changes withing one
> release.
> Should we think about 3.16 docs already?
> Regards,
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20200922/7fd6b238/attachment.html>
More information about the Qgis-community-team
