[Qgis-community-team] Testing documentation translation
    B. De Mezzo
    benoit.de.mezzo at oslandia.com
    Wed Sep 23 05:29:59 PDT 2020
I am a bit confused about this backport! According to what I have
understood from the PR
(https://github.com/qgis/QGIS-Documentation/pull/5930) the server manual
split should not be backported to the LTR.
Can I still push my translations to transifex or should I better wait
for the master to become the new LTR?
Regards,
BDM.
Le 22/09/2020 à 22:06, DelazJ a écrit :
> Hi Richard,
> Thanks for confirmation.
> About 3.10 backports, I agree with you, and Alexandre opened a
> discussion [0] a month ago but unfortunately that got no attention.
> About 3.16 docs, not sure what you meant (if different from the points
> raised in that discussion)
> [0]
> http://qgis-community-team.2324516.n4.nabble.com/Qgis-community-team-LTR-Documentation-soft-freeze-and-plans-for-the-future-td3377.html
> Regards,
> H.
> Le mar. 22 sept. 2020 à 21:57, Richard Duivenvoorde
> <rdmailings at duif.net <mailto:rdmailings at duif.net>> a écrit :
>     On 9/22/20 2:48 PM, DelazJ wrote:
>     > @Richard Duivenvoorde Can you please confirm that for someone
>     with sufficient rights (I do!), instructions at
>     https://github.com/qgis/QGIS-Documentation#translating are
>     uptodate and help to load changes to transifex? That way, we can
>     share the workload.
>     > And if you don't have time to do the update, I can handle it
>     later today.
>     Hi Harrissou,
>     I had to check (and by checking I also did it :-) ).
>     But yes, I can confirm that, using the venv, the instructions are
>     just fine \o/
>     As said: new sources are pushed to transifex, so happy translating !
>     One note: the rather big changes in files of 3.10 (because of the
>     backporting) is an exception now.
>     In normal scenario's there will not be such big changes withing
>     one release.
>     Should we think about 3.16 docs already?
>     Regards,
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20200923/3c71f1ef/attachment.html>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20200923/3c71f1ef/attachment.sig>
More information about the Qgis-community-team
