[Qgis-community-team] documentation - commit directly to	release_3.10
    Alexandre Neto
    senhor.neto at gmail.com
    Mon Sep 28 11:30:43 PDT 2020
Hello Larissa,
In QGIS\QGIS repository, change to the release_3.10 branch. Then, browse to
the file you want to change and click edit.
Change the file. In the end, it's asked if you want to update the file
directly or create a patch on your fork (I can't remember the exact
wording). Chose tge fork option.
That will create a branch on your repository that is based on release_3.10
branch.
Finally, when you try to create a pull request make sure to swap master
(which is the default) by the release_3.10 branch.
I hope it helps.
Alexandre Neto
A segunda, 28/09/2020, 14:59, Larissa Junek <l.junek at gmx.net> escreveu:
> Hello Alexandre and others,
> I'd like to commit directly to to the LTR documentation branch in the
> future.
> So far, I have a fork from the qgis/QGIS-Documentation repo. And there
> is a release_3.10 branch.
> My problem is that from my repository in the online system I'm not
> "linked" to the release_3.10 branch, only to the master of
> qgis/Documentation. So for now, I can't commit as I wanted.
> Can you help me to do the steps so that I can commit directly without
> using the backport to LTR option?
> Regards, Larissa
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20200928/c798de08/attachment.html>
More information about the Qgis-community-team
