[Qgis-developer] current SVN segfaults at start
Maciek Sieczka
werchowyna at epf.pl
Thu Apr 6 15:44:01 EDT 2006
$ qgis
Warning: fileVectorFilters, unknown driver: GRASS
Warning: fileVectorFilters, unknown driver: SQLite
gisBase = /usr/local/grass-6.1.cvs
Segmentation fault (core dumped)
backtrace:
(gdb) bt
#0 0xb55d69b1 in QgsGrassPlugin::mapsetChanged (this=0x8119270)
at qwidget.h:400
#1 0xb55da865 in QgsGrassPlugin::initGui (this=0x8119270)
at qgsgrassplugin.cpp:238
#2 0xb66ddee1 in QgisApp::loadPlugin (this=0x81181e0, name=
{static null = {<No data fields>}, static shared_null = {ref =
{atomic = 1422}, alloc = 0, size = 0, data = 0x804f4e2, clean = 0,
simpletext = 0, righttoleft = 0, asciiCache = 0, reserved = 0, array =
{0}}, static shared_empty = {ref = {atomic = 8}, alloc = 0, size = 0,
data = 0xb7e1199a, clean = 0, simpletext = 0, righttoleft = 0,
asciiCache = 0, reserved = 0, array = {0}}, d = 0x8342488, static
codecForCStrings = 0x0}, theFullPathName= {static null = {<No data
fields>}, static shared_null = {ref = {atomic = 1422}, alloc = 0, size
fields>= 0, data = 0x804f4e2, clean = 0, simpletext = 0, righttoleft =
fields>0, asciiCache = 0, reserved = 0, array = {0}}, static
fields>shared_empty = {ref = {atomic = 8}, alloc = 0, size = 0, data =
fields>0xb7e1199a, clean = 0, simpletext = 0, righttoleft = 0,
fields>asciiCache = 0, reserved = 0, array = {0}}, d = 0x82fbbb0,
fields>static codecForCStrings = 0x0}) at qgisapp.cpp:3704
#3 0xb66e3629 in QgisApp::restoreSessionPlugins (this=0x81181e0,
thePluginDirString=
data = 0xb7e1199a, clean = 0, simpletext = ---Type <return> to
continue, or q <return> to quit--- 0, righttoleft = 0, asciiCache = 0,
reserved = 0, array = {0}}, d = 0x8109ec8, static codecForCStrings =
0x0}) at qatomic.h:70
#4 0xb66f3f14 in QgisApp (this=0x81181e0, splash=0x0, parent=0x0,
#fl=Cannot access memory at address 0x0
at qatomic.h:70
#5 0x0804c213 in main (argc=1, argv=0xbf914ee4) at qglobal.h:1526
(gdb)
W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
