[Qgis-developer] Compiling QGIS on Debian Etch (testing-release)
Peter Ersts ersts at amnh.org
Mon Apr 10 11:12:05 EDT 2006
Thank you for the helpful responses to my initial questions regarding
plugin development.
Before diving into trying to develop a plugin, I thought I would try to
download and compile the most recent version of QGIS. I had some initial
trouble compiling QGIS on an older Debian box because of some GDAL
library conflicts with OpenEV. It was just a simple matter of modifying
the makefiles but I was unable to find a way to resolve the conflict
from the initial step using autogen.sh, so I chose to try a fresh
install of Debian on another box. Additionally, libgeos-dev was
initially missing and not explicitly mentioned in any of the build
instructions for Linux, though references to GEOS are in the OSX and
Windows build instructions. Once everything was in place the compilation
went beautifully and with out a hitch.
So I thought I would share the steps I took for compiling QGIS on a
fresh install of Debian Etch, testing release, just using packages and
libraries downloaded and installed with apt-get.
Great job on the newest version!
-pete
1) Download the GUI installer iso from
http://wiki.debian.org/DebianInstaller/GUI and burn to CD.  **For this
install I used the mini.ios (Intelx86) image which is only 9.2 megabytes.
2) Boot from the CD.
3) Follow the instructions for installing the Debian Etch (testing
release) desktop environment and standard system, which are the default
components to be installed. **This is a network install and I would not
recommend it for people with low bandwidth.
4) Login as a normal user and open a Terminal window.
5) In the Terminal window, become the superuser by typing:
        su root
6) Add your normal user to the sudoers list using:
        visudo
7) Exit from superuser account.
8) Install the necessary packages using the following commands;
        sudo apt-get install subversion automake1.9 libtool
libsqlite3-dev libgsl0-dev
        sudo apt-get install postgresql
        sudo apt-get install grass libgrass libgrass-dev libgeos-dev
        sudo apt-get install gdal-bin libgdal1-1.3.1-dev
        sudo apt-get install qt4-designer qt4-dev-tools
9) Update the system database
        sudo updatedb
10) Open a new Terminal window.
11) In the new terminal window, make a development directory for your
normal user:
        mkdir devel
12)  Enter the development directory and download the most recent
version of QGIS
        cd devel
        svn co https://svn.qgis.org/repos/qgis/trunk/qgis qgis-unstable
13) Enter the source directory and run autgen.sh.
        cd qgis-unstable
        ./autogen.sh --with-qtdir=/usr/share/qt4 --with-grass=/usr/lib/grass
14) If all of the packages are found simply type make to start compiling
QGIS
qgis 0.8.0
GDAL/OGR       : yes (Version 1.3.1)
GEOS                :yes (Version 2.1.4)
PostgreSQL       : yes (Version 8.1.0)
GRASS             : yes
SPIT                  : yes
Georeferencer     : yes
GPS/GPX           : yes
PROJ4               : yes
SQLITE3           : yes
Python                : no
Debug         : no
Plugin dir    : ${exec_prefix}/lib/qgis
The binary will be installed in /usr/bin
The build is using Qt in /usr/share/qt4
Linking with Qt using -lQtCore -lQt3Support -lQtGui -lQtNetwork -lQtSvg
-lQtCore -lQt3Support -lQtGui -lQtNetwork -lQtXml -lQtSvg -lQtTest
-lQtDesigner
Configure finished, type 'make' to build.
pete at mwavi:~/devel/Qgis/qgis-unstable$
15) Once the compilation is complete, install QGIS
        sudo make install
16) This is it!
**Note additional configuration may be necessary to get PostgreSQL and
other system component running properly and securely. Additional
packages may need to be installed if you choose to develop plugins using
KDevelop or anyother IDE.
Peter J. Ersts, Project Specialist
American Museum of Natural History
Center for Biodiversity and Conservation
Central Park West at 79th Street
New York, New York 10024
Tel: (212)-496-3488 or (212)-769-5742
Fax: (212)-313-7295 or (212)-769-5292
Web: http://cbc.amnh.org
Visit the Indo-South Atlantic Consortium on Humpback Whales
Web:  http://www.isach.org
