[Qgis-developer] Re: build_debian_package.sh in qgis-unstable
Neil Best
nbest at speakeasy.net
Mon Aug 28 10:01:02 EDT 2006
Tim, thanks for your reply. Another thing I tried with
qgis_0.7.9+svn20060826 on Ubuntu Dapper:
~/src/qgis-unstable$ sudo ./doCheckInstall.sh
make[6]: Entering directory
`/home/neil/src/qgis-unstable/src/widgets/projectionselector'
make[6]: Nothing to be done for `install-exec-am'.
test -z "/usr/local/lib/qgis" || mkdir -p -- . "/usr/local/lib/qgis"
true_fopen == 0 for fopen64("/proc/mounts", "r")
/bin/sh ../../../libtool --mode=install /usr/bin/install -c
'libqgsprojectionselector.la'
'/usr/local/lib/qgis/libqgsprojectionselector.la'
libtool: install: error: cannot install `libqgsprojectionselector.la' to
a directory not ending in /usr/lib/qgis
make[6]: *** [install-selectorLTLIBRARIES] Error 1
make[6]: Leaving directory
make[5]: *** [install-am] Error 2
make[5]: Leaving directory
make[4]: *** [install] Error 2
make[4]: Leaving directory
make[3]: *** [install-recursive] Error 1
make[3]: Leaving directory `/home/neil/src/qgis-unstable/src/widgets'
make[2]: *** [install-recursive] Error 1
make[2]: Leaving directory `/home/neil/src/qgis-unstable/src'
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory `/home/neil/src/qgis-unstable'
make: *** [install] Error 2
**** Installation failed. Aborting package creation.
Cleaning up...OK
Bye.
Then I thought I would update:
neil at gandalf:~/src/qgis-unstable$ svn update
svn: Working copy '.' locked
svn: run 'svn cleanup' to remove locks (type 'svn help cleanup' for details)
neil at gandalf:~/src/qgis-unstable$ svn status
? build-stamp
? debian
? nbest build notes
? patch-stamp
? doc-pak
L .
M build_debian_package.sh
~ autom4te.cache
neil at gandalf:~/src/qgis-unstable$ svn cleanup
svn: 'autom4te.cache' is not a working copy directory
I only know enough about svn to be dangerous, so I looked through the
docs and found out what '~' means, but couldn't see how to resolve it.
The only thing I can think of is to rm -r and re-checkout. What it is
autom4te.cache and what should I have done about it?
Not giving up yet,
Neil
Tim Sutton wrote:
> Hi Neil
> On 26/08/2006, at 16:37, Neil Best wrote:
>> Hi, Tim. I tried out the script that has your email address in it, so
>> when it didn't go well I thought I would send you a note. I am
>> running Ubuntu Dapper and inserted a "-d" after "fakeroot
>> dpkg-buildpackage" since I also have GRASS 6.1.0 installed from source
>> and the package manager is unaware that the libraries and headers are
>> in place (I think). It was compiling away quite merrily until:
>> dh_install --sourcedir=debian/tmp
>> cp: cannot stat `debian/tmp//usr/bin/gridmaker': No such file or directory
>> dh_install: command returned error code 256
>> make: *** [binary-arch] Error 1
>> [ so I looked for gridmaker ]
>> neil at gandalf:~/src/qgis-unstable$ ls debian/tmp/usr/bin/qgis
>> qgis qgis-config qgis_help
>> neil at gandalf:~/src/qgis-unstable$ ls debian//tmp/usr/bin/
>> What do you think is happening here?
> Thanks for the note. Steve Halasz maintains the debian/ packaging stuff
> - I just wrote the build package script. I actually use ubuntu so my
> copy of the debian/ dir is slightly forked to cope with different
> versions of gdal etc. Regarding the gridmaker error I'm not sure why
> you are getting that. Perhaps Steve has some ideas - Steve? I dont have
> access to my linux box till monday, Ill try to build the packages then
> and see if I get the same problem.
>> I have been referring to these pages on the QGIS web site:
>> "How to build qgis from cvs for Debian"
>> http://qgis.org/index.php?option=com_content&task=view&id=113&Itemid=99
>> <http://qgis.org/index.php?option=com_content&task=view&id=113&Itemid=99>
>> "Building QGIS on Ubuntu Step"
>> Step"http://qgis.org/index.php?option=com_content&task=view&id=99&Itemid=99
>> <http://qgis.org/index.php?option=com_content&task=view&id=99&Itemid=99>
>> Are these pages relevant/useful in your estimation?
> The debian install instructions look ok - they do seem to assume you
> already have gcc etc set up on your system - which you obviously have.
>> Should I be submitting this to the community? I welcome your
>> suggestions on how I can contribute. Thanks.
>> Neil
> Testing the package building process is already a great contribution! If
> you are looking for other things to do Ill be happy to point you in the
> right direction. Chiefly filing bugs on
> https://svn.qgis.org/trac
> Will be of the most use so we can get all the issues with the upcoming
> 0.8 release identified. If you are a coder, bug fixe patches will also
> be much appreciated.
> Its no problem to write to me personally, though the developers mailing
> list is usually a better option given the shared brain power they
> offer...I forwarded this to the list for now...
> Best regards
> Tim Sutton
> tim at linfiniti.com <mailto:tim at linfiniti.com>
