[Qgis-developer] Re: build_debian_package.sh in qgis-unstable
Tim Sutton
tim at linfiniti.com
Sat Aug 26 17:03:06 EDT 2006
Hi Neil
On 26/08/2006, at 16:37, Neil Best wrote:
> Hi, Tim. I tried out the script that has your email address in it,
> so when it didn't go well I thought I would send you a note. I am
> running Ubuntu Dapper and inserted a "-d" after "fakeroot dpkg-
> buildpackage" since I also have GRASS 6.1.0 installed from source
> and the package manager is unaware that the libraries and headers
> are in place (I think). It was compiling away quite merrily until:
> dh_install --sourcedir=debian/tmp
> cp: cannot stat `debian/tmp//usr/bin/gridmaker': No such file or
> directory
> dh_install: command returned error code 256
> make: *** [binary-arch] Error 1
> [ so I looked for gridmaker ]
> neil at gandalf:~/src/qgis-unstable$ ls debian/tmp/usr/bin/qgis
> qgis qgis-config qgis_help
> neil at gandalf:~/src/qgis-unstable$ ls debian//tmp/usr/bin/
> What do you think is happening here?
Thanks for the note. Steve Halasz maintains the debian/ packaging
stuff - I just wrote the build package script. I actually use ubuntu
so my copy of the debian/ dir is slightly forked to cope with
different versions of gdal etc. Regarding the gridmaker error I'm
not sure why you are getting that. Perhaps Steve has some ideas -
Steve? I dont have access to my linux box till monday, Ill try to
build the packages then and see if I get the same problem.
> I have been referring to these pages on the QGIS web site:
> "How to build qgis from cvs for Debian"
> http://qgis.org/index.php?
> option=com_content&task=view&id=113&Itemid=99
> "Building QGIS on Ubuntu Step" Step"http://qgis.org/index.php?
> option=com_content&task=view&id=99&Itemid=99
> Are these pages relevant/useful in your estimation?
The debian install instructions look ok - they do seem to assume you
already have gcc etc set up on your system - which you obviously have.
> Should I be submitting this to the community? I welcome your
> suggestions on how I can contribute. Thanks.
> Neil
Testing the package building process is already a great contribution!
If you are looking for other things to do Ill be happy to point you
in the right direction. Chiefly filing bugs on
https://svn.qgis.org/trac
Will be of the most use so we can get all the issues with the
upcoming 0.8 release identified. If you are a coder, bug fixe patches
will also be much appreciated.
Its no problem to write to me personally, though the developers
mailing list is usually a better option given the shared brain power
they offer...I forwarded this to the list for now...
Best regards
Tim Sutton
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20060826/19c13309/attachment.html
