[Qgis-developer] Questions and suggestion on build setup
    Tom Elwertowski
    telwertowski at comcast.net
    Mon Dec  4 17:53:31 EST 2006
William Kyngesburye wrote:
> I was messing around with an Xcode project for Qgis and noticed a couple
> oddities in the build (this is with preview 2 source):
> - projection selector is built as a library, and is not in the plugins
> or providers source folder, so it seems to be a core library for Qgis,
> yet it is installed in the plugins folder.  Shouldn't a library be kept
> with the rest of the libraries?  The grass provider library does.
I think it was an experiment in creating a Qt custom widget. From the
viewpoint of Qt Designer and the development process, it's somewhat like
a UI plugin. At runtime, however, it's essential to have the widget
present; it's not optional but could perhaps be replaced by an alternate
implementation.
We seem to have three classes of extras: Qt widgets, QGIS providers and
QGIS plugins. Implementations of the first are required, the third are
optional and I'm not fully sure about the second. Some providers are
optional but would QGIS work without the OGR provider?
Some extras are more important that others and perhaps should be sorted
into different folders for QGIS 1.0. As a product in development,
however, some of these distinctions are still fuzzy. Tim periodically
lobbies for greater use of UI widgets; when we implement more, we may
get a better feel for where they belong. For now, I have no objection to
the projection selector being installed in either place.
> - the scalebar plugin is the only one that has 'lib' prefixed to its
> name, and has mixed case:
> libScaleBarplugin
libwfsprovider also has the prefix but is not mixed case. My preference
is not to include 'lib' if 'plugin' or 'provider' is part of the name.
A related oddity is that most qgis libs have version 1.0.0 while raster
and msexport have version 0.0.0.
> Also, a suggestion for the Mac app packaging - organize it more Mac-like
> in the package.  Something like:
> Contents
>     Frameworks
>         qgis libs
>         Qt frameworks
>         other bundled shared libs
>     Headers
>     MacOS
>         qgis
>         qgis_config
>         qgis_help.app
>     PlugIns
>         qgis plugins
>         qt plugins
>     Resources
>         all share/qgis stuff
> The plugins is an odd one, because 'plugins' is the name of the Qt
> plugins folder, and 'PlugIns' is the standard OSX plugins folder name.
> Qt plugins I think needs to be in the samme place relative to the qt
> frameworks, but I don't know for sure, and there is probably some way to
> set that at runtime.  On a normal OSX file system, the case difference
> in the name shouldn't be a problem, but it would be on a case-sensitive
> HFS+ or UFS disk.
> The only changes needed are the resources and plugins path functions,
> and in the help app for locating the help data.
Personally, I like using the same paths as *nix so that changes made by
a *nix developer are likely to work on a Mac with no extra effort.
Most, maybe all, path names are encapsulated in accessor functions in
the QgsApplication class. You can try reorganizing the directories
yourself to see how feasible it is. If you get it working, you can give
us the changes.
A related issue are the helper applications. If really going the Mac
path route, they probably should be in a 'Utilities' folder alongside
QGIS rather then inside the bundle, especially apps like msexport,
gridmaker and spit.
Also, Qt 4.2 is now available as a dmg file so you might want to try
that as well. (Look in the 'previous versions' link which is actually
the complete Qt distribution directory.)
I'm more interested in rearranging dialog boxes (Qt 4.2 does support Mac
ordering of OK and Cancel buttons) than bundle directories but you
should feel free to try this yourself.
> PS. Xcode project is almost done, I'll turn it loose later in the week.
Tom
