[Qgis-developer] Questions and suggestion on build setup
    William Kyngesburye
    woklist at kyngchaos.com
    Mon Dec  4 18:25:46 EST 2006
On Dec 4, 2006, at 4:53 PM, Tom Elwertowski wrote:
>> - the scalebar plugin is the only one that has 'lib' prefixed to
>> its name, and has mixed case:
>> libScaleBarplugin
> libwfsprovider also has the prefix but is not mixed case. My
> preference is not to include 'lib' if 'plugin' or 'provider' is
> part of the name.
Makes more sense.  I didn't notice about wfs provider - preview 2
didn't enable that by default, so I skipped it.
>> The plugins is an odd one, because 'plugins' is the name of the Qt
>> plugins folder, and 'PlugIns' is the standard OSX plugins folder
>> name.  Qt plugins I think needs to be in the samme place relative
>> to the qt frameworks, but I don't know for sure, and there is
>> probably some way to set that at runtime.  On a normal OSX file
>> system, the case difference in the name shouldn't be a problem,
>> but it would be on a case-sensitive HFS+ or UFS disk.
I found where Qgis initializes the Qt plugin path if Qt frameworks
are embedded.  So I can adjust this as necessary (I put them in with
Qgis plugins for now in my experiment).
>> The only changes needed are the resources and plugins path
>> functions, and in the help app for locating the help data.
> Personally, I like using the same paths as *nix so that changes
> made by a *nix developer are likely to work on a Mac with no extra
> effort.
> Most, maybe all, path names are encapsulated in accessor functions
> in the QgsApplication class. You can try reorganizing the
> directories yourself to see how feasible it is. If you get it
> working, you can give us the changes.
I found those.  But the 'same paths as nix' is countered in these
because they have #ifdefs for whether it's a nix, mac or win build.
I was able to change these with no trouble.
> A related issue are the helper applications. If really going the
> Mac path route, they probably should be in a 'Utilities' folder
> alongside QGIS rather then inside the bundle, especially apps like
> msexport, gridmaker and spit.
Except that, if they link to Qgis libraries in the Qgis app, that's a
bad thing to do.  But don't those (havn't built msexport yet) build
as plugins?  At one time they may have built as executable variants,
I recall seeing these once, maybe in 0.7.
> Also, Qt 4.2 is now available as a dmg file so you might want to
> try that as well. (Look in the 'previous versions' link which is
> actually the complete Qt distribution directory.)
I'm starting the Xcode thing with the preview 2 source for now - can
that build with Qt 4.2 as is?  Once I get the bulk of the Xcode
project settled (actually, almost done), I'll switch over to SVN
source and Qt 4.2.
> I'm more interested in rearranging dialog boxes (Qt 4.2 does
> support Mac ordering of OK and Cancel buttons) than bundle
> directories but you should feel free to try this yourself.
One big plus with Xcode is that a universal build is super easy.  And
the app bundle packaging is automatic.
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that
the past isn't a fiction designed to account for the discrepancy
between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
