[GRASS-dev] Re: [Qgis-developer] QGIS Windows Snapshot - with WMS
and SPIT
Martin Dobias
wonder.sk at gmail.com
Sat Dec 9 08:13:25 EST 2006
Hi Tim,
looking at my notes from the time I've been trying to build grass with
mingw, I've found out that I had similar problem and I think that this
has helped:
./configure (... usual options ...) --with-includes=/usr/include
--with-libs=/usr/lib
I guess that you'll need to use /usr/local prefix instead of just /usr
Hope that helps,
Martin
On 12/9/06, Tim Sutton <tim at linfiniti.com> wrote:
> HI Markus
> Ill need to get back in to work to check on my linux box what version
> is in the chroot for cross compiling. The current version of grass in
> the windows build is just translocated binaries from that xcompiled
> build set up by Radim - pending my ability to get grass to build
> properly in msys. If a grass guru can help me get grass compiling in
> our msys environment I would be happy to track the head version of
> grass (or latest stable if you prefer) for the future releases.
> Currently when I run configure I get:
> checking for library containing cuserid... no
> checking for xdrmem_create... no
> checking for xdrmem_create in -lsun... no
> checking for xdrmem_create in -lnsl... no
> checking for xdrmem_create in -lrpclib... no
> checking for xdrmem_create in -lxdr... no
> configure: error: *** Unable to locate XDR functions.
> I configured using:
> ./configure --build=i686-pc-mingw32 \
> --without-curses \
> --without-jpeg \
> --without-tiff \
> --without-png \
> --without-tcltk \
> --without-postgres \
> --without-mysql \
> --without-sqlite \
> --without-opengl \
> --without-odbc \
> --without-fftw \
> --without-blas \
> --without-lapack \
> --without-motif \
> --without-freetype \
> --without-glw \
> --without-nls \
> --without-readline \
> --without-opendwg \
> --without-x
> I have xdr installed in the msys environment here:
> cria at NOTE3 /src/xdr-4.0-mingw2
> $ make install
> Creating RPC header directory
> mkdir -p /usr/local/include/rpc && \
> chmod 755 /usr/local/include/rpc
> Installing XDR header files
> set -x;for i in rpc/types.h rpc/xdr.h ; do \
> (install -c -m 644 $i /usr/local/include/rpc) done
> + install -c -m 644 rpc/types.h /usr/local/include/rpc
> + install -c -m 644 rpc/xdr.h /usr/local/include/rpc
> Installing XDR library
> install -c -m 644 libxdr.a /usr/local/lib
> ranlib /usr/local/lib/libxdr.a
> Any hints would be greatly appreciated. The msys environment can be
> downloaded at
> http://qgis.org/uploadfiles/msys/msys.tar.bz2
> If any grass gurus want to give it a go I would be most greatful for
> the help. Because I havent uploaded my latest local copy of the msys
> environment, note that grass needs to be updated from cvs there and
> you may need to grab xdr from
> http://wiki.qgis.org/qgiswiki/BuildingWindowsBinaryOnLinux?action=AttachFile&do=get&target=xdr-4.0-mingw2.tar.gz
> Regards
> Tim
> On 12/9/06, Markus Neteler <neteler at itc.it> wrote:
> > Hi Tim,
> > great work!
> > Would you mind to update README.txt in
> > http://qgis.org/uploadfiles/testbuilds/
> > and add which GRASS version (with date) you used?
> > We have fixed a lot of MingW problems lately, so
> > it would be helpful to know that in order to better
> > understand if you are looking at old or new problems.
> > thanks
> > Markus
> > On Fri, Dec 08, 2006 at 07:50:06PM -0600, Tim Sutton wrote:
> > > Hi Soren
> > > Thanks very much for the useful feedback. At this point I am still
> > > using the grass modules from crosscompiled grass. Until I can get
> > > grass to build natively under msys it will be difficult for me to
> > > resolve these. Currently grass configure fails to find XDR rpc lib
> > > even though I have sucessfully build and installed XDR.
> > > I'll try to work something out for though....
> > > Regards
> > > Tim
> > > On 12/8/06, "Sören Gebbert" <soerengebbert at gmx.de> wrote:
> > > >Hi Tim,
> > > >thanks great work!
> > > >I have checked the grass modules with the grass-test-suite.
> > > >The result is available here:
> > > >http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite/html_win32/
> > > >Here are some screenshots of the qgis-grass shell with some test-suite run
> > > >results:
> > > >http://www-pool.math.tu-berlin.de/~soeren/grass/modules/screenshots/Qgis_0_8_Grass_6_3_Mingw_TestSuite_general_db.png
> > > >http://www-pool.math.tu-berlin.de/~soeren/grass/modules/screenshots/Qgis_0_8_Grass_6_3_Mingw_TestSuite_rast3d_vector.png
> > > >http://www-pool.math.tu-berlin.de/~soeren/grass/modules/screenshots/Qgis_0_8_Grass_6_3_Mingw_TestSuite_raster.png
> > > >Most of the modules are working well, only r3.info seems to have
> > > >problems with windows.
> > > >Best regards
> > > >Soeren
> > > >-------- Original-Nachricht --------
> > > >Datum: Fri, 8 Dec 2006 17:01:59 -0600
> > > >Von: "Tim Sutton" <tim at linfiniti.com>
> > > >An: qgis-developer <qgis-developer at lists.qgis.org>, qgis-user
> > > ><qgis-user at lists.qgis.org>
> > > >Betreff: [Qgis-developer] QGIS Windows Snapshot - with WMS and SPIT
> > > >> Hi
> > > >> I've uploaded a new snapshot of QGIS for windows with WMS raster
> > > >> support and SPIT plugint:
> > > >> http://qgis.org/uploadfiles/testbuilds/qgis_setup.exe
> > > >> Regards
> > > >> Tim Sutton
> > > >> Visit http://qgis.org for a great Open Source GIS
> > > >> Home Page: http://linfiniti.com
> > > >> Skype: timlinux
> > > >> MSN: tim_bdworld at msn.com
> > > >> Yahoo: tim_bdworld at yahoo.com
> > > >> Jabber: timlinux
> > > >> Irc: timlinux on #qgis at freenode.net
> > > >> _______________________________________________
> > > >> Qgis-developer mailing list
> > > >> Qgis-developer at lists.qgis.org
> > > >> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
> > > >"Ein Herz für Kinder" - Ihre Spende hilft! Aktion: www.deutschlandsegelt.de
> > > >Unser Dankeschön: Ihr Name auf dem Segel der 1. deutschen America's
> > > >Cup-Yacht!
> > > Tim Sutton
> > > Skype: timlinux
> > > Jabber: timlinux
> > > grass-dev mailing list
> > > grass-dev at grass.itc.it
> > > http://grass.itc.it/mailman/listinfo/grass-dev
> > Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
> > ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
> > MPBA - Predictive Models for Biol. & Environ. Data Analysis
> > Via Sommarive, 18 - 38050 Povo (Trento), Italy
> Tim Sutton
> Skype: timlinux
> Jabber: timlinux
