[Qgis-developer] qgis 0.8pre2 on suse10.2
Otto Dassau otto.dassau at gmx.de
Wed Dec 20 07:49:00 EST 2006
thanks for the hint, the devel packages were in /usr/include/Qt, so
export QTDIR=/usr works.
Now I have another problem. SuSe 10.2 unfortunately doesn't include GEOS, so I
compiled and installed current GEOS-3.0.0rc3 and QGIS complains because it
expects a GEOS 2.x.x Version.
Where and what do I have to change to adapt the test? Or do I need to stick with
GEOS 2.x.x?
 thanks again
  Otto
On Tue, 19 Dec 2006 17:37:13 -0500
Mike Leahy <mgleahy at alumni.uwaterloo.ca> wrote:
> Hello Otto,
> Look for an rpm called something like qt4-devel for your distribution -
> the devel packages are what usually install the header files.
> Mike
> Otto Dassau wrote:
> > Hi,
> > I try to compile qgis pre2 on an opensuse 10.2 with qt4.2.1. QGIS doesn't
> > find the header files like qglobal.h under /usr/lib/qt4/include. They don't
> > exist and I don't know what further packages I need to install, because I
> > thinkt I already installed all qt4 rpms that come with the distribution.
> > Under download.qgis.org/qgis/ there is already a
> > qgis-0.8.0_preview-1_no_grass.i586.rpm for suse 10. Was this package built
using
> > qt4 from suse or using compiled qt4 sources?
> > Maybe someone knows a trick how to build the preview2 under suse 10.
> > thanks a lot
> >  Otto
> > Qgis-developer mailing list
> > Qgis-developer at lists.qgis.org
> > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
