[Qgis-developer] rendering current line in Grass digitizer is
very slow
Radim Blazek
radim.blazek at gmail.com
Mon Jul 10 05:00:09 EDT 2006
GRASS edit in 0.8 is using QgsRubberBand (XOR rendering
does not work anymore IIRC) and it is probably slow because
it is not designed for complex graphics.
I dont know if it can be improved.
Radim
On 7/7/06, Maciek Sieczka <werchowyna at epf.pl> wrote:
> Hi,
> Lines in Grass digitizer are being drawn really slowly on pretty fast
> computers [1]. The more vertices the line has, the slower the
> rendering. The bug affects only the line being currently digitized, ie.
> if you just try to modify an existing one by moving or adding
> single vertices rendering is fast. But when you digitize a long line,
> with each vertex added the rendering speed decreases.
> To reproduce:
> 1. Open a Grass vector in Grass digitizer.
> 2. Start a new line (or boundary) by putting the first vertex. See how
> smoothly the line is drawn as you move the cursor with mouse.
> 3. Now digitize 10, 100, 300 etc. vertices. See how much slower the
> rendering gets with each vertex put. Note the slow-down does not depend
> on the zoom level or the amount of features being displayed. The only
> "reason" for the slow-down is the amount of vertices you have put in
> the line being currently digitized.
> Is this a known issue? Is my description clear? Could it be fixed?
> Using SVN 0.8 of yesterday, Ubuntu Breezy and Dapper.
> Maciek
> [1]
> PM 1,86 GHz, ATI X700 128MB, propriearty drivers, direct rendering on
> AMD 3200, NVIDIA GX400 64MB, propriearty drivers, direct rendering on
> W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
> http://katalog.panoramainternetu.pl/
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
