[Qgis-developer] problem with suse10.1 and autotools
humarco marco.hugentobler at karto.baug.ethz.ch
Wed Jul 26 10:02:36 EDT 2006
Hi qgis devs,
I'm trying to compile QGIS at the computer of a workmate (suse 10.1). When the
autogen.sh script is run, the following error message appears:
checking machine/endian.h usability... no
checking machine/endian.h presence... no
checking for machine/endian.h... no
checking for X... libraries /usr/X11R6/lib, headers /usr/X11R6/include
./configure: line 19554: syntax error near unexpected token `QT,'
./configure: line 19554: `    PKG_CHECK_MODULES(QT, QtCore QtGui
Qt3Support QtNetwork QtXml QtSvg QtTest >= $QT_MIN_VER)'
autogen was run with the following options:
./autogen.sh --with-qtdir=/home/idaniel/qt4
--with-gdal=/home/idaniel/gdal/gdal-1.3.2/bin/gdal-config
--with-projdir=/home/idaniel/proj-4.4.9
--with-geos=/home/idaniel/geos-2.2.3 --prefix=/home/idaniel/qgis
and the versions of the autotools are the following:
automake 1.9.6
autoconf 2.59
libtool 1.5.2.2
Any autotool guru can help me with this?
thanks,
Marco
