[Qgis-developer] problem with suse10.1 and autotools
Tim Sutton tim at linfiniti.com
Thu Jul 27 19:09:09 EDT 2006
Hi
What version of Qt4 do you have?
Regards
Tim
On 26/07/2006, at 11:02, humarco wrote:
> Hi qgis devs,
> I'm trying to compile QGIS at the computer of a workmate (suse
> 10.1). When the
> autogen.sh script is run, the following error message appears:
> checking machine/endian.h usability... no
> checking machine/endian.h presence... no
> checking for machine/endian.h... no
> checking for X... libraries /usr/X11R6/lib, headers /usr/X11R6/include
> ./configure: line 19554: syntax error near unexpected token `QT,'
> ./configure: line 19554: `    PKG_CHECK_MODULES(QT, QtCore QtGui
> Qt3Support QtNetwork QtXml QtSvg QtTest >= $QT_MIN_VER)'
> autogen was run with the following options:
> ./autogen.sh --with-qtdir=/home/idaniel/qt4
> --with-gdal=/home/idaniel/gdal/gdal-1.3.2/bin/gdal-config
> --with-projdir=/home/idaniel/proj-4.4.9
> --with-geos=/home/idaniel/geos-2.2.3 --prefix=/home/idaniel/qgis
> and the versions of the autotools are the following:
> automake 1.9.6
> autoconf 2.59
> libtool 1.5.2.2
> Any autotool guru can help me with this?
> thanks,
> Marco
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
Tim Sutton
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20060727/0757fd10/attachment.html
