[Qgis-developer] problem with suse10.1 and autotools
humarco
marco.hugentobler at karto.baug.ethz.ch
Thu Jul 27 02:16:26 EDT 2006
Hi Tim,
Qt 4.1.4
Am Donnerstag, 27. Juli 2006 23:09 schrieb Tim Sutton:
> Hi
> What version of Qt4 do you have?
> Regards
> Tim
> On 26/07/2006, at 11:02, humarco wrote:
> > Hi qgis devs,
> > I'm trying to compile QGIS at the computer of a workmate (suse
> > 10.1). When the
> > autogen.sh script is run, the following error message appears:
> > checking machine/endian.h usability... no
> > checking machine/endian.h presence... no
> > checking for machine/endian.h... no
> > checking for X... libraries /usr/X11R6/lib, headers /usr/X11R6/include
> > ./configure: line 19554: syntax error near unexpected token `QT,'
> > ./configure: line 19554: ` PKG_CHECK_MODULES(QT, QtCore QtGui
> > Qt3Support QtNetwork QtXml QtSvg QtTest >= $QT_MIN_VER)'
> > autogen was run with the following options:
> > ./autogen.sh --with-qtdir=/home/idaniel/qt4
> > --with-gdal=/home/idaniel/gdal/gdal-1.3.2/bin/gdal-config
> > --with-projdir=/home/idaniel/proj-4.4.9
> > --with-geos=/home/idaniel/geos-2.2.3 --prefix=/home/idaniel/qgis
> > and the versions of the autotools are the following:
> > automake 1.9.6
> > autoconf 2.59
> > libtool 1.5.2.2
> > Any autotool guru can help me with this?
> > thanks,
> > Marco
> > Qgis-developer mailing list
> > Qgis-developer at lists.qgis.org
> > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
> Tim Sutton
> tim at linfiniti.com
