[Qgis-developer] Re: My TODO
Radim Blazek radim.blazek at gmail.com
Tue Jun 6 05:15:36 EDT 2006
I forgot,
Composer:
+ check if mCachePixmap (map,legend, scalebar) cannot be changed when
  it is painted on canvas
Radim
On 6/5/06, Radim Blazek <radim.blazek at gmail.com> wrote:
> Here is what remains on my private TODO for 0.8.
> Hopefully someone else can do it because I'll become
> home/computerless soon and I dont know when I'll be back.
> Radim
> ========= GRASS ===========
> + missing raster maps in mapcalc GUI on Windows
> + use QgsLogger::debug/warning everywhere
> + add tr() everywhere (write a script which finds all strings without tr)
> + fix src/plugins/grass/Makefile.win (sometimes happens
>    that .libs/grassplugin.dll is not compiled properly (small size)
>    and recompilation does not work, necessary to remove
>    .libs/grassplugin.dll and recompile)
> + add to 'Known problems' (somewhere):
>     GRASS - db drivers : problems with pipe buffer on NT5.1, works on NT5.2
> ========= COMPOSER ========
> + feature labels scaling (PS)
> + font size - use only the sizes which corresponds to integers used in PS
> + improve map preview rendering (depends on specified resolution -> slow)
> + fix picture editing (wrong bounding box?)
> + PS output to file: rewrite page size only for non standard page sizes
> ========= OTHER ============
> + render point symbols as vectors (QPicture), important for printing
> + Vector feature selection: enable remove features from selection set
> with Ctrl/Shift
>                             (invert selection of feature)
> + Labels: does not work for multi* features
> + replace all assert() by reasonable error message, dont exit!
> + crash when attribute table is opened immediately after start of QGIS
> with project
> ======== BUILD SYSTEM (MinGW) =====
> + Add clean to Makefiles.win
> + Compilation of DLL does not work well, for example qgis_legend.dll contains
>   functions from qgsspatialrefsys.cpp
