[Qgis-developer] Re: My TODO
Tim Sutton
tim at linfiniti.com
Tue Jun 6 19:15:21 EDT 2006
Hi
I will still fix the pixmapcache issue on your todo list....my life
is also a bit upside down right now but I didnt forget about it....
Regards
Tim
Em 06/06/2006, às 06:15, Radim Blazek escreveu:
> I forgot,
> Composer:
> + check if mCachePixmap (map,legend, scalebar) cannot be changed when
> it is painted on canvas
> Radim
> On 6/5/06, Radim Blazek <radim.blazek at gmail.com> wrote:
>> Here is what remains on my private TODO for 0.8.
>> Hopefully someone else can do it because I'll become
>> home/computerless soon and I dont know when I'll be back.
>> Radim
>> ========= GRASS ===========
>> + missing raster maps in mapcalc GUI on Windows
>> + use QgsLogger::debug/warning everywhere
>> + add tr() everywhere (write a script which finds all strings
>> without tr)
>> + fix src/plugins/grass/Makefile.win (sometimes happens
>> that .libs/grassplugin.dll is not compiled properly (small size)
>> and recompilation does not work, necessary to remove
>> .libs/grassplugin.dll and recompile)
>> + add to 'Known problems' (somewhere):
>> GRASS - db drivers : problems with pipe buffer on NT5.1, works
>> on NT5.2
>> ========= COMPOSER ========
>> + feature labels scaling (PS)
>> + font size - use only the sizes which corresponds to integers
>> used in PS
>> + improve map preview rendering (depends on specified resolution -
>> > slow)
>> + fix picture editing (wrong bounding box?)
>> + PS output to file: rewrite page size only for non standard page
>> sizes
>> ========= OTHER ============
>> + render point symbols as vectors (QPicture), important for printing
>> + Vector feature selection: enable remove features from selection set
>> with Ctrl/Shift
>> (invert selection of feature)
>> + Labels: does not work for multi* features
>> + replace all assert() by reasonable error message, dont exit!
>> + crash when attribute table is opened immediately after start of
>> QGIS
>> with project
>> ======== BUILD SYSTEM (MinGW) =====
>> + Add clean to Makefiles.win
>> + Compilation of DLL does not work well, for example
>> qgis_legend.dll contains
>> functions from qgsspatialrefsys.cpp
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
Tim Sutton
