[Qgis-developer] configure error
Tom Elwertowski
telwertowski at comcast.net
Thu Jun 8 11:45:41 EDT 2006
Kirk,
This might have something to do with using (or not using) pkg-config,
which was added earlier this year to help certain *nix distributions
find Qt4. Since this change, I have needed to add the following item to
QGIS's configure:
--with-qtdir=/usr/local/Trolltech/Qt-4.1.3
Although pkg-config works on a Mac for *nix libraries, it doesn't
understand frameworks and Qt is built as a framework rather than a
traditional library by default. Consequently, pkg-config can't find it.
Also, when you get past this, you will need to edit
$QTDIR/lib/libQtTest.la and remove or comment the line beginning
dependency_libs=
Tom
Kirk R. Wythers wrote:
> I am trying to compile the unstable head on OS X. I'm getting a
> configure error.
> checking for X... libraries /usr/X11R6/lib, headers /usr/X11R6/include
> ./configure: line 19937: syntax error near unexpected token `QT,'
> ./configure: line 19937: ` PKG_CHECK_MODULES(QT, QtCore QtGui
> Qt3Support QtNetwork QtXml QtSvg QtTest >= $QT_MIN_VER)'
> I just build and installed qt4 and set up my environment as such:
> # Qt4 environment
> QTDIR=/Developer/qt-mac-opensource-src-4.1.3
> PATH=/usr/local/Trolltech/Qt-4.1.3/bin:$PATH
> DYLD_LIBRARY_PATH=$QTDIR/lib:$DYLD_LIBRARY_PATH
> export QTDIR PATH MANPATH DYLD_LIBRARY_PATH
> Anyone see what I missed?
> Thanks
