[Qgis-developer] bug count
humarco
marco.hugentobler at karto.baug.ethz.ch
Mon Jun 12 11:00:33 EDT 2006
Right, tetex-extra was missing.
Marco
Am Montag, 12. Juni 2006 16:36 schrieb Stephan Holl:
> Hello humarco,
> On Mon, 12 Jun 2006 16:37:26 +0200 humarco
> <marco.hugentobler at karto.baug.ethz.ch> wrote:
> > Hi Stephan,
> > I just updated my doc svn copy and when i run make, i got this:
> > ! LaTeX Error: File `scrartcl.cls' not found.
> this is from the koma-package. On debian it is in
> tetex-extra: /usr/share/texmf/tex/latex/koma-script/scrartcl.cls
> dpkg -S scrartcl.cls
> > and when i press return
> > ! LaTeX Error: File `float.sty' not found.
> > Type X to quit or <RETURN> to proceed,
> > or enter new name. (Default extension: sty)
> again, tetex-extra is missing:
> dpkg -S float.sty
> > Enter file name:
> > ! Undefined control sequence.
> > <recently read> \floatstyle
> > l.17 \floatstyle
> > {ruled}
> > I have teTex from the ubuntu dapper repository. Do i need to install
> > anything else?
> probably tetex-extra.
> > Of course i will add the new legend stuff (probably next week since i
> > will be away for a couple of days).
> > Thanks for your work anyway!
> hope you can compile now!
> Best
> Stephan
> > Marco
> > Am Montag, 12. Juni 2006 15:59 schrieb Stephan Holl:
> > > Let me jump in here as well. Since Otto and me have made some sort
> > > of improvements to the manual, we would like to encurage every dev
> > > looking into the current SVN-manual (perhaps between 2 soccer
> > > matches ;-)
> > > My intention is to make every dev to have a look at their
> > > implemented part and check if the stuff described in the manual is
> > > up-to-date.
> > > I have worked on the GRASS-integration and added mostly all new
> > > GRASS-related features.
> > > What I recall now is that the new legend is not described at all. If
> > > you could provide some details on usage I am happy to add
> > > text/screeners to the manual.
> > > Best regards
> > > Stephan
