[Qgis-developer] QGIS Docs
Martin Dobias wonder.sk at gmail.com
Tue Jun 13 10:51:57 EDT 2006
On 6/12/06, Stephan Holl <holl at gdf-hannover.de> wrote:
> Let me jump in here as well. Since Otto and me have made some sort of
> improvements to the manual, we would like to encurage every dev looking
> into the current SVN-manual (perhaps between 2 soccer matches ;-)
> My intention is to make every dev to have a look at their
> implemented part and check if the stuff described in the manual is
> up-to-date.
here are my notes to the docs (rev. 149):
- 3.6.3. Stopping Rendering: currently it's not possible to stop
rendering - this was disabled in qt4 port because of UI problems and
crashes
- 3.6.6. Updating the Map Display During Rendering: also not working -
AFAIK the same problem
(these problems probably could be IMO solved only by rendering in a
worker thread and that's quite a lot of work)
- 4.5.: Marco has been doing recently some work on editing support -
is the doc up-to-date?
- 6.2.: it would be good to mention that it's possible to select more
layers at once which will produce one QGIS layer with all selected
layers
- E.8.: instructions are still for Qt3
What could be added:
- some information about displaying and using attribute table for
vector layers (and the possibility to search features in table by
attributes using the SQL-like syntax)
- descibe measure tool a bit: now measures real distance on ellipsoid
(with possibility to select preferred ellipsoid in settings) and can
measure also areas
Greetings,
Martin
