[Qgis-developer] QGIS Docs
Otto Dassau dassau at gdf-hannover.de
Tue Jun 13 14:58:50 EDT 2006
thanks for your notes Martin. Maybe we can set up a wiki site for this
and try to collect and implement all suggestions. What do you think?
regards,
   Otto
> On 6/12/06, Stephan Holl <holl at gdf-hannover.de> wrote:
>> Let me jump in here as well. Since Otto and me have made some sort of
>> improvements to the manual, we would like to encurage every dev looking
>> into the current SVN-manual (perhaps between 2 soccer matches ;-)
>> My intention is to make every dev to have a look at their
>> implemented part and check if the stuff described in the manual is
>> up-to-date.
> Hi,
> here are my notes to the docs (rev. 149):
> - 3.6.3. Stopping Rendering: currently it's not possible to stop
> rendering - this was disabled in qt4 port because of UI problems and
> crashes
> - 3.6.6. Updating the Map Display During Rendering: also not working -
> AFAIK the same problem
> (these problems probably could be IMO solved only by rendering in a
> worker thread and that's quite a lot of work)
> - 4.5.: Marco has been doing recently some work on editing support -
> is the doc up-to-date?
> - 6.2.: it would be good to mention that it's possible to select more
> layers at once which will produce one QGIS layer with all selected
> layers
> - E.8.: instructions are still for Qt3
> What could be added:
> - some information about displaying and using attribute table for
> vector layers (and the possibility to search features in table by
> attributes using the SQL-like syntax)
> - descibe measure tool a bit: now measures real distance on ellipsoid
> (with possibility to select preferred ellipsoid in settings) and can
> measure also areas
> Greetings,
> Martin
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
