[Qgis-developer] QGIS Docs
Martin Dobias wonder.sk at gmail.com
Tue Jun 13 17:35:41 EDT 2006
Hi Otto,
first I thought that creating a wiki page is not needed and that
mailing list is good enough for discussing this. But when looking
towards the next features (and releases), it might be good to have a
'Documentation TODO' page where developers (or users) could add some
brief notes about new features. This can enable documentation
maintainers to focus on the areas that need attention.
Martin
On 6/13/06, Otto Dassau <dassau at gdf-hannover.de> wrote:
> Hi,
> thanks for your notes Martin. Maybe we can set up a wiki site for this
> and try to collect and implement all suggestions. What do you think?
> regards,
>    Otto
> > On 6/12/06, Stephan Holl <holl at gdf-hannover.de> wrote:
> >> Let me jump in here as well. Since Otto and me have made some sort of
> >> improvements to the manual, we would like to encurage every dev looking
> >> into the current SVN-manual (perhaps between 2 soccer matches ;-)
> >> My intention is to make every dev to have a look at their
> >> implemented part and check if the stuff described in the manual is
> >> up-to-date.
> > Hi,
> > here are my notes to the docs (rev. 149):
> > - 3.6.3. Stopping Rendering: currently it's not possible to stop
> > rendering - this was disabled in qt4 port because of UI problems and
> > crashes
> > - 3.6.6. Updating the Map Display During Rendering: also not working -
> > AFAIK the same problem
> > (these problems probably could be IMO solved only by rendering in a
> > worker thread and that's quite a lot of work)
> > - 4.5.: Marco has been doing recently some work on editing support -
> > is the doc up-to-date?
> > - 6.2.: it would be good to mention that it's possible to select more
> > layers at once which will produce one QGIS layer with all selected
> > layers
> > - E.8.: instructions are still for Qt3
> > What could be added:
> > - some information about displaying and using attribute table for
> > vector layers (and the possibility to search features in table by
> > attributes using the SQL-like syntax)
> > - descibe measure tool a bit: now measures real distance on ellipsoid
> > (with possibility to select preferred ellipsoid in settings) and can
> > measure also areas
> > Greetings,
> > Martin
> > Qgis-developer mailing list
> > Qgis-developer at lists.qgis.org
> > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
