[Qgis-developer] Re: Problems with Windows DLLs
Radim Blazek
radim.blazek at gmail.com
Fri Jun 30 14:03:05 EDT 2006
I know that it can happen sometimes, deleting
src/plugins/xxx/.libs/xxxplugin.dll + make -f Makefile.win install
should resolve it there must be a bug in makefiles but I dont know
where, it seems to be ok. The problem is that
src/plugins/xxx/.libs/xxxplugin.dll is created but it is corrupted.
We could simply delete that file always when make is called
but that is not clean solution.
Radim
On 6/30/06, Gary Sherman <sherman at mrcc.com> wrote:
> I've almost completed the windows build for the preview release, however
> there is a recurring issue. The plugin DLLs are not linked properly and
> aren't recognized as a valid qgis plugin. I had this happen once and
> through an unknown combination of clean/configure/build I got back to
> where they worked. Now they are broken again.
> Any of you x-compiling wizards have a thought? I'm following the build
> instructions on the wiki.
> -gary
> -_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
> Gary Sherman
> Micro Resources: http://mrcc.com
> *Geospatial Hosting
> *Web Site Hosting
> "We work virtually everywhere"
