[Qgis-developer] unable to compile plugin with SVN Version
Gavin Macaulay
gavin at macaulay.co.nz
Fri May 19 05:26:18 EDT 2006
The plugin interface was altered slightly last week...
The way in which a plugin creates and deletes an entry in the plugins menu
is different now. The QAction that was created for the icon in a toolbar
is now also used for the menu entry. See the
src/plugins/north_arrow/plugin.cpp file for an example.
Regards
Gavin
Last week I created a little plugin sogis with the plugin_builder.pl. The
> plugin compiled and worked fine. Today I tried to compile the latest SVN
> Version of QGIS and the compilation process crashes at my plugin code with
> the following error message.
> sogis.cpp: In member function `virtual void sogis::initGui()':
> sogis.cpp:93: error: 'class QgisIface' has no member named 'getPluginMenu'
> I'm doubt about whether there were made any modifications of the
> QgisIface.
> With best regards
> Dr. Horst Düster
> GIS-Koordinator, Stv. Amtschef
> Kanton Solothurn
> Amt für Geoinformation
> Abteilung SO!GIS® Koordination
> Rötistrasse 4
> CH-4501 Solothurn
> Tel.: ++41 (0)32 627 25 32
> Fax: ++41 (0)32 627 22 14
> horst.duester at bd.so.ch
> www.sogis.so.ch
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
