AW: [Qgis-developer] unable to compile plugin with SVN Version
Düster Horst
Horst.Duester at bd.so.ch
Fri May 19 10:44:09 EDT 2006
Gavin
Thank you very much for your hint. Now it works.
With best regards
Dr. Horst Düster
GIS-Koordinator, Stv. Amtschef
Kanton Solothurn
Amt für Geoinformation
Abteilung SO!GIS® Koordination
Rötistrasse 4
CH-4501 Solothurn
Tel.: ++41 (0)32 627 25 32
Fax: ++41 (0)32 627 22 14
horst.duester at bd.so.ch
www.sogis.so.ch
> -----Ursprüngliche Nachricht-----
> Von: Gavin Macaulay [mailto:gavin at macaulay.co.nz]
> Gesendet am: Freitag, 19. Mai 2006 10:26
> An: qgis-developer at lists.qgis.org
> Betreff: Re: [Qgis-developer] unable to compile plugin with
> SVN Version
> Hi,
> The plugin interface was altered slightly last week...
> The way in which a plugin creates and deletes an entry in the
> plugins menu
> is different now. The QAction that was created for the icon
> in a toolbar
> is now also used for the menu entry. See the
> src/plugins/north_arrow/plugin.cpp file for an example.
> Regards
> Gavin
> Last week I created a little plugin sogis with the
> plugin_builder.pl. The
> > plugin compiled and worked fine. Today I tried to compile
> the latest SVN
> > Version of QGIS and the compilation process crashes at my
> plugin code with
> > the following error message.
> > sogis.cpp: In member function `virtual void sogis::initGui()':
> > sogis.cpp:93: error: 'class QgisIface' has no member named
> 'getPluginMenu'
> > I'm doubt about whether there were made any modifications of the
> > QgisIface.
> > With best regards
> > Dr. Horst Düster
> > Kanton Solothurn
> > Rötistrasse 4
> > CH-4501 Solothurn
> > www.sogis.so.ch
> > Qgis-developer mailing list
> > Qgis-developer at lists.qgis.org
> > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
