[Qgis-developer] Windows build
Radim Blazek radim.blazek at gmail.com
Thu May 25 03:58:14 EDT 2006
Windows machine is not required for compilation, currently
I compile with cross compiler on Windows. It is necessary
however for testing.
Compilation on Windows with MinGW would be probably even easier,
recently I tried also IDE based on MinGW which works smoothly.
(http://www.bloodshed.net/devcpp.html)
For those who work on Linux it can be interesting to know that
rdesktop (Windows Terminal Server client) on Linux works
without problems and you can use also Windows XP Profesional
as terminal server (for 1 client). It means that if you have a computer
with XP Profesional which is not used in your local network,
you can compile on Linux and test in rdesktop - terminal server.
Wine does not work well, it can only be used for simple tests.
Radim
On 5/24/06, Paolo Cavallini <cavallini at faunalia.it> wrote:
> Too bad! I cannot help (I do not own a win machine, no win experience, little
> compilation skills, etc), but if someone can, please do.
> A good windows installer will be of paramount importance for the success of
> qgis (and grass too).
> All the best, and many thanks to Radim for his work.
> pc
> At 17:26, mercoledì 24 maggio 2006, Radim Blazek has probably written:
> > Hi.
> > I won't be able to create Windows builds of QGIS 0.8 for longer period
> > after June 15. If somebody else wants to continue in Windows builds,
> > I can help now.
> > Radim
> > Qgis-developer mailing list
> > Qgis-developer at lists.qgis.org
> > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
> Paolo Cavallini
> email+jabber: cavallini at faunalia.it
> www.faunalia.it
> Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy   Tel: (+39)348-3801953
