[Qgis-developer] Change symbol \\ using jpeg image \\ and
	proj(delimited text)
    Schalk Snyman
    snymans at wbs.co.za
    Thu Oct  5 02:23:57 EDT 2006
Hi Martin,
Thanks again for reply!
> Yes it's possible, it depends on whether you have jpeg support
> compiled in GDAL library. QGIS currently doesn't support projections
> for raster layers.
I don't see any use for jpeg as a map if you cannot set the
projection :-( Guess I'll have to use the shapefiles (perhaps simplified
to save on loading time)
> I haven't tried the code I've written here so maybe they won't work...
> it's just how I think they should work :-)
Worked perfectly last time! :-)
Best Regards.
Schalk
